Galaxy DX Radios DX45MP
Dimmer PCB (EPT091V40A)
Trace Layout
Schematic Diagram
Schematic Diagram
Parts List
Ref#
Description
MFR. Part No.
DIMMER PCB Complete with Components
#T-141Q-P10
DIMMER PCB
EPT091V40A
Resistors
Ref#
Description
MFR. Part No.
R402
C/F/R F-TYPE 12K OHM 1/16W U
RCU161234Z
R403
C/F/R P-TYPE 47K OHM 1/16W P
RCP164734Z
R404
C/F/R F-TYPE 10K OHM 1/4W U
RCU141034Z
R405
C/F/R 3.3K OHM 1/4W U
RCU143324Z
R406
C/F/R F-TYPE 47 OHM 1/16W U
RCU164704Z
R407
C/F/R F-TYPE 1K OHM 1/16W U
RCU161024Z
R408
RCU164704Z
R409
C/F/R P-TYPE 15 OHM 1/16W P
RCP161504Z
Capacitors
Ref#
Description
MFR. Part No.
C401
E/C 47UF 16WV Z (MINI)
CEM164767Z
C402
CEM164767Z
C403
C/C 0.01UF 50WV SL Z
CC0501037L
C404
CC0501037L
C405
CC0501037L
C406
CC0501037L
C407
CEM164767Z
Transistors
Ref#
Description
MFR. Part No.
Q401
T/R 2SC945P
T2SC00945P
Q402
T/R 2SC945P
T2SC00945P
Q403
T/R DTC124ES
TDTC0124ES
Lamps
Ref#
Description
MFR. Part No.
Lamp 401
LAMP 0.05A 12V RED
EX02N40229
Lamp 402
LAMP 0.05 12V CLEAR
EX02N40230
Connectors
Ref#
Description
MFR. Part No.
J401
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J402
PCB CONNECTOR/S 5P PH=2MM (WHITE)
EX07W48826
J403
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J406
EX07N48223
Jumper
Ref#
Description
MFR. Part No.
JP401
JUMPER WIRE 7x10x7
WX01070710
Copyright © 2003 CBTricks.com
