Galaxy DX Radios DX45MP
EL Driver PCB (EPT91V130Z)
Schematic Diagram
Schematic Diagram
Ref#
Description
MFR. Part No.
EL DRIVER PCB Complete with Components
#T-141Q-P14
EL DRIVER PCB 22x15x1.6tmm(S)
EPT91V130Z
Parts List
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/C (SMD) 0.1UF 25WV Z Y5V
CK2104AD7R
R2
CHIP/F/R (SMD) 0 OHM PCS
RCY060004Z
R3
RCY060004Z
R4
CHIP/F/R (SMD) 180K OHM 5%
Later Production 56K OHM 5%
RCY061844Z
RCY065634Z
R5
CHIP/F/R (SMD) 1K OHM
RCY061024Z
Capacitors
Ref#
Description
MFR. Part No.
C1
CHIP/C (SMD) 0.47UF 16WV Z Y5V
CK5474AD7R
C2
CHIP/C (SMD)0.1UF 50WV K X7R
CK1104AB5X
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C. (SMD) SM8144BV-E2 8PIN
YNSN8144BV
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL (SMD) 220UH TE K
YCTLI2274E
Diode
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1N4148
ED1N04148Y
D2
ZENER DIODE (SMD) RLZ5.1BT6-11
EDZD05519Y
Connectors
Ref#
Description
MFR. Part No.
PCB CONNECTOR/S 5P L=12mm PH=2.5
EX07N48265
WIRE CONNECTOR/H P PH=2mm L=50mm
EX07N48539
Hardware
Ref#
Description
MFR. Part No.
  SHIELD HOUSING
MT240N060X
FOAM H14x14x2
XZZZ90053Z
Copyright © 2003 CBTricks.com
