Galaxy
DX Radios DX45MP
Chassis and Miscellaneous Parts
Ref#
Description |
MFR.
Part No.
ROTARY SW 8N L=20MM |
EWRT32077S |
SPEAKER 8 OHM 3W 3.5in |
ES300835SQ |
METER P-48N-9359 |
EX03N40502 |
MIC JACK� 4P |
EX06N41101 |
TERMINAL CONNECTOR NP-1203 |
EX06N41036 |
ANT JACK |
EX06T41019 |
DC SOCKET (#18) 2P W/WIRE 100MM |
EX07N49257 |
REAR HEATSINK |
MTDX91010A |
LEFT SIDE CHASSIS |
MTDX91020X |
RIGHT SIDE CHASSIS |
MTDX91030X |
NUT WITH WASHER M3x3.5t |
JN263035ZS |
FRONT PANEL DX-45MP |
PTDX55062A |
KNOB WASHER |
PT3600090A |
CH |
DISPLAY WINDOW ORANGE |
PTDX55020A |
FRONT PANEL |
DISPLAY BAR |
PTDX55040A |
Rotate SW |
CH KNOB TR-396 |
PT148N021A |
Dual VR(INNER) |
INNER KNOB |
PT148N100A |
Single VR(B083) |
VR KNOB TR-396 |
PT148N031A |
Dual CR(OUTER) |
OUTER KNOB |
PT148N090A |
EL ID PLATE DX-45MP |
BTDX55120B |
FRONT CHASSIS (D) DX-45MP |
MTDX55070X |
SW CHASSIS |
MTDX55042X |
HANDLER |
MT3600030S |
HOUSING |
MT2950031A |
BOTTOM HOUSING |
MT2950041A |
DC/S fixed plate |
MT3600180A |
Bottom Housing(SP) |
SHIELD CLOTH 60x50x0.25t |
LZZZ60084Z |
CLAMP GT-100M |
GZZZ50000Z |
ON SETER |
MTDX55080N |
Ref#
Description |
MFR.
Part No.
FOAM 15x30x11t |
XZZZ90021Z |
SOLDER PLATE 3.2mm |
XZZZ90002Z |
POWER PCB |
SPONGE 15x11x15mm |
XZZZ90406Z |
MIC JACK(2) |
SOLDER PLATE |
XZZZ90098Z |
900020Z(2) |
SET SCREW M2x0.4Px4 |
JS052004MN |
REAR HEATSINK(2) |
JS052004MN |
Front panel (4) |
SET SCREW M3x0.5Px6 |
JS033006MN |
CHASSIS(2) |
SET SCREW M3x0.5Px4 |
JS053004MN |
CH(2) |
JS053006MN |
Chassis(10) |
JS053006MN |
MAIN PCB(1) |
JS053006MN |
Main PCB(4) |
SET SCREW T3x6-2mm |
JS053006TN |
SET CHASSIS(2) |
JS053006TN |
MAIN PCB(2) |
SET SCREW T3x4-2 |
JS053004TN |
SHIELD COVER(PA)(6) |
JS053006MN |
HEATSINK(4) |
SET SCREW M5x0.75Px8 |
JS055008MB |
SET SCREW W5x10-1 |
JS015010WH |
SET SCREW� T3.5x8-2 |
JS013508TH |
OUT-TOOTH WASHER 5.5x10x0.3tmm |
JW315510CN |
IN-TOOTH WASHER 4x8x0.3tmm |
JW324008CN |
Ref#
Description |
MFR.
Part No.
MICROPHONE ASSY,4P BLACK DMC507-012 |
EX04N40002 |
DC CORD (#18) 3000MM |
WA9818300C |
Galaxy |
GALAXY MIC NAME PLATE |
BT2100020A |
MOUNTING SCREW BLACK |
XZZZ90007Z |
MIC STOPPER |
XZZZ90008Z |
FIBER WASHER |
XZZZ90188Z |
SHIELD CLOTH 10x88x0.3t |
LZZZ60001Z |
