Galaxy
DX Radios DX45MP
VR PCB (EPT048T40Z)
Trace Layouts
Ref#
Description |
MFR.
Part No.
VR PCB Complete with Components |
#T-141Q-P04 |
VR P.C.B. 104x32x1.6tmm(S) |
EPT048T40Z |
Resistors
Ref#
Description |
MFR.
Part No.
R401 |
CHIP/F/R (SMD) 0 OHM 0.1W |
RCY010004Z |
Capacitors
Ref#
Description |
MFR.
Part No.
C401 |
CHIP/C (SMD) 0.01UF 25WV Z Y5V |
CK2103AB7R |
C402 |
CK2103AB7R |
C403 |
CK2103AB7R |
C404 |
CHIP/F/R (SMD) 10K OHM 0.1W |
RCY011034Z |
Transistors
Ref#
Description |
MFR.
Part No.
Q402 |
T/R (SMD) DTA124EK |
TYDTA124EK |
Inductors
Ref#
Description |
MFR.
Part No.
L401 |
CHOKE COIL (SMD) 5.6UH TC J |
YCTLI5653C |
L402 |
BEAD FERRITE COIL WB-403025 |
YCBAD18581 |
Connectors
Ref#
Description |
MFR.
Part No.
J401 |
PCB CONNECTOR/S 3P T PH=2.5 |
EX07N41216 |
J403 |
PCB CONNECTOR/S 2P PH=2MM |
EX07N48223 |
J404 |
EX07N48223 |
J405 |
PCB CONNECTOR/S 5P PH=2MM (WHITE) |
EX07W48826 |
J407 |
PCB CONNECTOR/S 3P PH=2MM (WHITE) |
EX07W48824 |
J409 |
PCB CONNECTOR/S 3P PH=2MM |
EX07N48350 |
J410 |
EX07W48824 |
J412 |
EX07N48223 |
J413 |
EX07N48350 |
J415 |
EX07N48223 |
J416 |
EX07N48223 |
J417 |
EX07N48350 |
Pots
Ref#
Description |
MFR.
Part No.
ECHO/TIME |
V/R 50KB/50KA |
RV50303578 |
MIC/RF |
VR 1KB/1KA |
RV10203524 |
VOL/SQ |
VR 50KB/50KA W/SW |
RV50303522 |
