Galaxy DX Radios DX48T
Chassis and Miscellaneous Parts
Ref#
Description
MFR. Part No.
ANT JACK
EX06T41019
MIC JACK 4P
EX06N41101
EAR JACK3.5mm
EX06N41045
LEFT SIDE CHASSIS
MTDX91020X
HEATSINK(PA)
MT2970060A
REAR HEATSINK
MTDX91010A
SHIELD COVER(Power Amp)
MT2970090X
POWER CORD(#12) 3000MM
WA9212300Q
Ref#
Description
MFR. Part No.
FRONT PANEL DX-48T
PTDX55062A
FRONT CHASSIS (D) DX-48T
MTDX55070X
CH
DISPLAY WINDOW ORANGE
PTDX55020A
FRONT PANEL
DISPLAY BAR
PTDX55040A
EL ID PLATE DX-48T
BTDX55120A
Ref#
Description
MFR. Part No.
Rotate SW
CH KNOB TR-396
PT148N021A
Dual VR(INNER)
INNER KNOB
PT148N100A
Single VR
VR KNOB TR-396
PT148N031A
Dual CR(OUTER)
OUTER KNOB
PT148N090A
KNOB WASHER
PT3600090A
Ref#
Description
MFR. Part No.
MICROPHONE ASSY,4P BLACK DMC507-012
EX04N40002
Galaxy
MIC NAME PLATE GALAXY
BT2100020A
MIC STOPPER
XZZZ90008Z
Ref#
Description
MFR. Part No.
SHIELD COVER
(Power Amp)
SET SCREW M3x0.5Px4
JS013004MN
DC FAN(4)
SET SCREW M3x0.5Px16
JS013016MB
HEATSINK(4)
SET SCREW M5x0.75Px8
JS055008MB
90002Z(2)
SET SCREW M2x0.4Px4
JS052004MN
REAR HEATSINK(2)
SET SCREW M2x0.4Px4
JS052004MN
TR41
SET SCREW M2x0.4Px8
JS052008MN
Front panel (4)
SET SCREW M3x0.5Px6
JS033006MN
CHASSIS(2)
SET SCREW M3x0.5Px4
JS053004MN
CH(2)
SET SCREW M3x0.5Px6
JS053006MN
Chassis(10)
SET SCREW M3x0.5Px6
JS053006MN
MAIN PCB(1)
SET SCREW M3x0.5Px6
JS053006MN
Speaker(4)
SET SCREW M3x0.5Px8
JS053008MN
Main PCB(4)
SET SCREW T3x6-2mm
JS053006TN
MAIN PCB(2)
SET SCREW T3x4-2
JS053004TN
METER PCB(4)
SET SCREW M2.6x0.45Px4
JS052604MN
SLIDE SW(10)
JS052604MN
MOUNTING SCREW BLACK
XZZZ90007Z
SET SCREW W5x10-1
JS015010WH
SET SCREW T3.5x8-2
JS013508TH
Ref#
Description
MFR. Part No.
OUT-TOOTH WASHER 5.5x10x0.3tmm
JW315510CN
IN-TOOTH WASHER 4x8x0.3tmm
JW324008CN
FIBER WASHER
XZZZ90188Z
SP
NUT WITH WASHER M3x3.5t
JN263035ZS
Ref#
Description
MFR. Part No.
HANDLER
MT3600030S
DC/S fixed plate
MT3600180A
Bottom Housing(SP)
SHIELD CLOTH 45x0.25t
LZZZ60036Z
CLAMP
GZZZ50000Z
ON SETER
XZZZ90001B
SLIDE SW(5)
MASK PLATE(SW)
XZZZ90296A
FOAM15x30x11t
XZZZ90021Z
POWER PCB
SPONGE 15x11x15mm
XZZZ90406Z
SOLDER PLATE
XZZZ90098Z
SOLDER PLATE H3.2mm
XZZZ90002Z
SSSEB51H K905 271X 1219x0.8(SECC)0.15
HZZZ76005Z
POLYLON BOTTOM
UPT360001B
POLYLON COVER
UPT297001D
Copyright © 2002 CBTricks.com
