Galaxy DX Radios DX48T
Transmitter Alignment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
TX OSC:
Set Radio to BAND E
CH 1 RX AM
Connect Frequency counter to TP5
L23
10.69500Mhz ± 20Hz .
TX Power:
Set radio Band E, CH 1.
AM TX mode. Modulation off.
RF PWR control to max.
Connect RF Power Meter with 50 ohm dummy load to antenna jack.
L40,L42,
L43,L44
max. power with min. spurious emission. Balance Power between Band A CH. 1 and
Band H CH. 40
RF Carrier Adjust:
AM TX mode,
Modulation off
Connect wattmeter with 50 ohm dummy load to  output.
Set RF PWR control to min.
VR14
(high power)
VR18
(low power)
40 watts on wattmeter.
10 watts on wattmeter.
RF Power Meter:
AM TX mode, Modulation off
VR9
50 on PWR scale.
AM Modulation:
AM TX mode
RF PWR to max.
Inject AF signal 30 mV,
1 KHz to microphone input.
Connect modulation meter  with 50 ohm dummy load to ANT output.
VR16
90% modulation
AM Modulation Meter:
AM TX mode
RF PWR to max.
VR15
90 on the mod scale
FM Deviation:
Set radio Band E, CH. 1
FM TX mode.
RF PWR to max.
Connect deviation meter with 50 ohm dummy load to ANT output.
VR5
4KHz on Deviation Meter
SWR Auto CAL:
AM TX mode, Modulation off.
RF PWR to max.
Set SWR/MOD/PWR switch to SWR position.
Connect 100 ohm load (2:1)
to ANT output.
VR1 on
(EPA010020B)
located on amplifier pcb
2 on the SWR scale.
Copyright © 2002 CBTricks.com
