Galaxy
DX Radios DX55HP
Dimmer
PCB (EPT55V-51Z)
Trace Layout
Ref# | Description |
MFR.
Part No.
DIMMER P.C.B. EPT055V51Z |
#T-140O-P05 |
DIMMER P.C.B. 42x52x1.6tmm(S) |
EPT055V51Z |
Resistors
Ref#
Description |
MFR.
Part No.
R1 |
C/F/R 47 OHM 1/4W U |
RCU144704Z |
R2 |
C/F/R F-TYPE 10K OHM 1/4W U |
RCU141034Z |
R3 |
C/F/R 3.3K OHM 1/4W U |
RCU143324Z |
R4 |
RCU141034Z |
R5 |
C/F/R 2.2K OHM 1/4W U |
RCU142224Z |
R6 |
RCU141034Z |
R7 |
RCU142224Z |
R8 |
C/F/R 4.7K OHM 1/4W M |
RCM144724B |
R9 |
C/F/R 47K OHM 1/4W U |
RCU144734Z |
R10 |
C/F/R 1K OHM 1/4W M |
RCM141024B |
R11 |
C/F/R F-TYPE 1K OHM 1/4W U |
RCU141024Z |
Capacitors
Ref#
Description |
MFR.
Part No.
C1 |
E/C 47UF 16WV Z |
CE0164767Z |
C2 |
E/C 10UF 25WV Z |
CE0251067Z |
C3 |
E/C 47UF 16WV Z |
CE0164767Z |
C4 |
C/C 0.01UF 50WV SL Z |
CC0501037L |
C5 |
CC0501037L |
C6 |
CC0501037L |
��Transistors
Ref#
Description |
MFR.
Part No.
Q1 |
T/R 2SC945P |
T2SC00945P |
Q2 |
T/R 2SC945P |
T2SC00945P |
Q3 |
T/R 2SC945P |
T2SC00945P |
Q4 |
T/R 2SC945P |
T2SC00945P |
Lamps
Ref#
Description |
MFR.
Part No.
LAMP 0.05A 12V RED |
EX02N40229 |
LAMP 0.05 12V |
EX02N40230 |
Connectors
Ref#
Description |
MFR.
Part No.
J1 |
PCB CONNECTOR/S 3P T PH=2.5(WHITE) |
EX07N41227 |
J1 |
WIRE CONNECTOR/H 3P L=120MM |
EX07N48192 |
J2 |
PCB CONNECTOR/S 2P T PH=2.5(WHITE) |
EX07N41330 |
J2 |
WIRE CONNECTOR/H 2P L=180MM |
EX07N48041 |
J3 |
PCB CONNECTOR/S 2P PH=2.5 |
EX07N41226 |
J3 |
WIRE CONNECTOR/H 2P L=160MM |
EX07N48196 |
J4 |
EX07N41226 |
J4 |
WIRE CONNECTOR/H 2P L=100MM |
EX07N48195 |
Hardware
Ref#
Description |
MFR.
Part No.
(4) |
SET SCREW M2.6x0.45Px4 |
JS052604MN |
