Galaxy
DX Radios DX55V
Extended 10-Meter Frequency Conversion (26.965 - 29.655MHz)
NOTE: If you have even the slightest doubts or the proper equipment , it would be wise to have someone else you trust perform the mod for you. SO TAKE YOUR TIME AND DOUBLE CHECK YOUR WORK!!!! |
1.
Remove
the covers from the radio and locate X2 (grid location E2 Main PCB). |
2.
Replace
X2 14.010MHz crystal to a 15.360MHz crystal. |
3.
Do a complete
Alignment of the radio. |
4.
Re-Assemble
the unit and check All Bands and functions for Proper operation. |
This will give you the following freqs. in order.
Band A = 26.965 - 27.405
Band B = 27.415 - 27.855
Band C = 27.865 - 28.305
Band D = 28.315 - 28.755
Band E = 28.765 - 29.205
Band F = 29.215 - 29.655
This will cover almost the complete 10 meter range 28.000 - 29.700 and still keep the 11 meter CB.
