Galaxy DX Radios DX55V
Frequency Counter PCB (EPT210014D)
(Started with later 2005 Production)
EPT210014D Trace Layouts
Schematic Diagram
Ref#
Description
MFR. Part No.
EPT210014D Counter PCB Complete with Components.
#T-118W1-P03
COUNTER P.C.B.  162x51x1.6tmm(d)
EPT210014D
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/F/R (SMD) 2.2K OHM 0.1W
RCY012224Z
R2
CHIP/F/R (SMD) 47 OHM 0.1W
RCY014704Z
R3
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R4
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R5
RCY014724Z
R6
CHIP/F/R (SMD) 330 OHM 0.1W
RCY013314Z
R7
RCY011034Z
R8
RCY011034Z
R9
RCY011034Z
R10
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R11
RCY011034Z
R12
RCY013314Z
R13
RCY011034Z
R14
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R15
CHIP/F/R (SMD) 39K OHM 0.1W
RCY013934Z
R16
RCY014704Z
R17
RCY013314Z
R18
CHIP/F/R (SMD) 220 OHM 0.1W
RCY012214Z
R19
CHIP/F/R (SMD) 1M OHM 0.1W
RCY011054Z
R20
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R21
CHIP/F/R (SMD) 680 OHM 0.1W
RCY016814Z
R22
RCY016814Z
R23
RCY016814Z
R24
RCY016814Z
R25
RCY016814Z
R26
RCY016814Z
R27
RCY016814Z
R28
RCY016814Z
R29
RCY016814Z
R30
RCY016814Z
R31
RCY016814Z
R32
RCY016814Z
R33
RCY016814Z
R34
RCY016814Z
R35
RCY016814Z
R36
RCY016814Z
R37
RCY016814Z
R38
RCY016814Z
R39
RCY016814Z
R40
RCY016814Z
R41
RCY016814Z
R43
RCY011034Z
R44
RCY011034Z
R45
RCY011034Z
R46
RCY011024Z
Capacitors
Ref#
Description
MFR. Part No.
C1
E/C 100UF 16WV H=5mm
CEM161077A
C2
CHIP/C 0.1UF 50WV Z F Y5V
CK1104AB7R
C3
CK1104AB7R
C4
CK1104AB7R
C5
CEM161077A
C7
CHIP/C 0.01UF 50WV M Z5U K X7R
CK1103AB6U
C8
CK1103AB6U
C9
CK1103AB6U
C10
E/C 100UF 16WV Z
CE0161077Z
C11
CK1103AB6U
C12
CK1103AB6U
C13
CK1104AB7R
C14
CK1103AB6U
C15
CK1103AB6U
C16
CEM161077A
C17
CHIP/C 15PF 50WV J CH
CK1150AB4A
C19
CK1104AB7R
C20
CK1103AB6U
C21
CK1104AB7R
C22
CK1104AB7R
C23
CK1104AB7R
C24
CK1104AB7R
C25
CK1104AB7R
C26
CK1104AB7R
C27
CK1104AB7R
Ref#
Description
MFR. Part No.
VC1
TRIMMER/C (SMD) 20PF TCZ03P200A110B00
CV038200AY
Integrated Circuit
Ref#
Description
MFR. Part No.
IC1
I.C.(JRC) (SMD) NJM78L05UA-TE1
YNJR78L05Z
IC2
I.C.(PHILIPS) (SMD) 74HC161D 16PIN PCS
YNPHHC161D
IC3
I.C.(RANGER) (SMD) HT48R50A-48 48PIN PCS
YNRGFC04SP
Crystals
Ref#
Description
MFR. Part No.
X1
CRYSTAL HC-49/U 4.500MHz
EYCAP04500
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1SS355
EDSS00355Y
D2
DIODE (SMD) 1SS355
EDSS00355Y
D3
DIODE (SMD) 1N4148
ED1N04148Y
D4
DIODE (SMD) 1N4148
ED1N04148Y
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q2
TY2SC2712G
Q3
T/R (SMD) 2SC2714Y-TE85L (T5L)
TY2SC2714Z
Q4
T/R (SMD) 2SA1162GR-TE85L
TY2SA1162G
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL (SMD) 100UH TF J
YCTLI1073F
Connectors
Ref#
Description
MFR. Part No.
CN1
PCB CONNECTOR/S 7P PH=2MM
EX07N48224
CN2
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
CN3
PCB CONNECTOR/S 12P PH=2
EX07N48150
CN4
PCB CONNECTOR/S 12P PH=2(WHITE)
EX07N48767
Copyright © 2005 CBTricks.com
