Galaxy DX Radios DX55V
CHASSIS PARTS
Ref#
Description
MFR. Part No.
Vol-SO
V/R 50KA/50KB W/SW
RV50303433
MIC / Gain-RF Gain
V/R 1KB/1KA
RV10203588
RF Power
V/R 1KB/1KA W/SW
RV10203590
CLARIFIER
V/R 20KB
RV20303392
KNOB WASHER
PT3600090A
Rotate SW
KNOB (A-1)
PT3600101A
Dual VR(INNER)
KNOB B-1(CHROM)
PT3600110A
Single VR
KNOB C-1
PT3600120A
Dual VR(OUTER)
KNOB D-1(CHROM)
PT3600130A
ROTATE SW
D SPRING A #6600
MT3600080T
DUAL VR (INNER)
D SPRING B #7800
MT3600090T
DUAL VR (OUTER)
D SPRING D #8500
MT3600100T
Band
ROTARY SW 6N
EWRT32038S
SPEAKER 8ohm 3W 3.5in
ES300835SQ
Speaker(4)
SET SCREW M3x0.5Px8
JS053008MN
SP
NUT WITH WASHER M3x3.5t
JN263035ZS
DC CORD W/FUSE SOCKET
WA0012185A
DC JACK 3P
EX06T40007
DC SOCKET HOLDER
MT3600050X
DC SOCKET(2)
SET SCREW M3x0.5Px8
JS053008MN
DIODE LT6A400
EDLT6A400Z
FUSE 16V 4A
EX02N40008
SIGNAL METER
EX03N40461
Ref#
Description
MFR. Part No.
CR
FRONT PANEL
PTDX55010A
DX-55V
FRONT CHASSIS
MTDX55013X
SW CHASSIS
MTDX55042X
SET CHASSIS
MT3001021M
HANDLER
MT3600030S
TOP HOUSING
MT3600061X
BOTTOM HOUSING
MT3600071X
Top & Bottom Housing
SHIELD CLOTH 10x170x0.3t
LZZZ60082Z
CLAMP GT-100M
GZZZ50000Z
FOAM 15x30x11t
XZZZ90021Z
INSULATING PLATE 18x13mm
XZZZ90020Z
INSULATING PLATE 10x14x1.55mm
XZZZ90358Z
SPONGE D 30x53x6t
XZZZ90078Z
FRONT PANEL
INSULATION SHEET 16x97x0.6tmm
XZZZ90309Z
Front panel (4)
SET SCREW M3x0.5Px6
JS033006MN
CH(2)
SET SCREW M3x0.5Px6
JS053006MN
Chassis(10)
SET SCREW M3x0.5Px6
JS053006MN
Trs-1
SET SCREW M2x0.4Px10
JS052010MN
SET SCREW M3x0.5Px6
JS013006MV
Main PCB(7)
SET SCREW T3x6-2mm
JS053006TN
NUT M2x1.2t
JN242012ZS
MICROPHONE ASSY,4P BLACK DMC507-012
EX04N40002
MIC STOPPER
XZZZ90008Z
MOUNTING SCREW BLACK
XZZZ90007Z
SET SCREW W5x10-1
JS015010WH
SET SCREW T3.5x8-2
JS013508TH
OUT-TOOTH WASHER 5.5x10x0.3tmm
JW315510CN
IN-TOOTH WASHER 4x8x0.3tmm
JW324008CN
FIBER WASHER
XZZZ90188Z
Copyright © 2003 CBTricks.com
