Galaxy DX Radios DX66V
Dimmer PCB (EPT55V-51Z)
Schematic Diagram
Trace Layout
Ref# Description
MFR. Part No.
DIMMER PCB EPT055V51Z Complete with Components
#T-140O-P05
DIMMER PCB 42x52x1.6tmm(S)
EPT055V51Z
Resistors
Ref#
Description
MFR. Part No.
R1
C/F/R 47 OHM 1/4W U
RCU144704Z
R2
C/F/R F-TYPE 10K OHM 1/4W U
RCU141034Z
R3
C/F/R 3.3K OHM 1/4W U
RCU143324Z
R4
RCU141034Z
R5
C/F/R 2.2K OHM 1/4W U
RCU142224Z
R6
RCU141034Z
R7
RCU142224Z
R8
C/F/R 4.7K OHM 1/4W M
RCM144724B
R9
C/F/R 47K OHM 1/4W U
RCU144734Z
R10
C/F/R 1K OHM 1/4W M
RCM141024B
R11
C/F/R F-TYPE 1K OHM 1/4W U
RCU141024Z
Capacitors
Ref#
Description
MFR. Part No.
C1
E/C 47UF 16WV Z
CE0164767Z
C2
E/C 10UF 25WV Z
CE0251067Z
C3
E/C 47UF 16WV Z
CE0164767Z
C4
C/C 0.01UF 50WV SL Z
CC0501037L
C5
CC0501037L
C6
CC0501037L
Lamps
Ref#
Description
MFR. Part No.
LAMP 0.05A 12V RED
EX02N40229
LAMP 0.05A 12V
EX02N40230
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R 2SC945P
T2SC00945P
Q2
T/R 2SC945P
T2SC00945P
Q3
T/R 2SC945P
T2SC00945P
Q4
T/R 2SC945P
T2SC00945P
Connectors
Ref#
Description
MFR. Part No.
J1
PCB CONNECTOR/S 3P T PH=2.5(WHITE)
EX07N41227
J1
WIRE CONNECTOR/H 3P L=120MM PCS 1
EX07N48192
J2
PCB CONNECTOR/S 2P T PH=2.5(WHITE)
EX07N41330
J2
WIRE CONNECTOR/H 2P L=180MM
EX07N48041
J3
PCB CONNECTOR/S 2P PH=2.5
EX07N41226
J3
WIRE CONNECTOR/H 2P L=160MM
EX07N48196
J4
EX07N41226
J4
WIRE CONNECTOR/H 2P L=100MM
EX07N48195
Hardware
Ref#
Description
MFR. Part No.
DIMMER PCB
SET SCREW M2.6x0.45Px4 (4)
JS052604MN
Copyright © 1998,1999,2000, 2001, 2002, 2003 CBTricks.com
