Galaxy DX Radios DX66V
Chassis Parts
Ref# Description
MFR. Part No.
Vol-SO
V/R 50KA/50KB W/SW
RV50303433
MIC Gain-RF Gain
V/R 1KB/1KA
RV10203588
DIM / RF PWR
V/R 1KB/1KA W/SW
RV10203590
CLARIFIER
V/R 20KB
RV20303392
ROTARY SW 4N
EWRT32008S
Rotate SW
KNOB (A-1)
PT3600101A
Dual VR(INNER)
KNOB B-1(CHROM)
PT3600110A
Single VR
KNOB C-1
PT3600120A
Dual CR(OUTER)
KNOB D-1 (CHROM)
PT3600130A
ROTATE SW
D SPRING A #6600
MT3600080T
DUAL VR (INNER)
D SPRING B #7800
MT3600090T
DUAL VR (OUTER)
D SPRING D #8500
MT3600100T
VR E-SW
INSULATION SHEET 16x97x0.6tmm
XZZZ90309Z
E-TONE-SW
XZZZ90309Z
KNOB WASHER
PT3600090A
Ref# Description
MFR. Part No.
SPEAKER 8ohm 3W 3.5in
ES300835SQ
SP
NUT WITH WASHER M3x3.5t
JN263035ZS
Speaker(4)
SET SCREW M3x0.5Px8
JS053008MN
SIGNAL METER
EX03N40461
MICROPHONE ASSY, 4P BLACK DMC507-012
EX04N40002
ANT JACK
EX06T41019
EAR JACK 3.5mm
EX06N41045
DC JACK 3P
EX06T40007
DC SOCKET(2)
SET SCREW M3x0.5Px8
JS053008MN
DC SOCKET HOLDER
MT3600050X
DIODE LT6A400
EDLT6A400Z
DC CORD W/FUSE SOCKET
WA0012185A
FUSE 16V 4A
EX02N40008
Ref# Description
MFR. Part No.
CR
FRONT PANEL
PTDX55010A
DX-66V
FRONT CHASSIS
MTDX55023X
SET CHASSIS
MT3001021M
HANDLER
MT3600030S
TOP HOUSING
MT3600061X
BOTTOM HOUSING
MT3600071X
Top Housing
SHIELD CLOTH 10x170x0.3t
LZZZ60082Z
Bottom Housing
LZZZ60082Z
PCB BRACKET
MT3001010S
Galaxy
MIC NAME PLATE
BT2100020A
ID PLATE H
BTDX55020A
CLAMP GT-100M
GZZZ50000Z
FOAM 15x30x11t
XZZZ90021Z
INSULATING PLATE 18x13mm
XZZZ90020Z
SPONGE D 30x53x6t
XZZZ90078Z
INSULATING PLATE 12x16x1t
XZZZ90064Z
INSULATING PLATE 10x14x1.55mm
XZZZ90358Z
Front panel (4)
SET SCREW M3x0.5Px6
JS033006MN
Chassis(9)
SET SCREW M3x0.5Px6
JS053006MN
Trs-1
SET SCREW M2x0.4Px10
JS052010MN
SET SCREW M3x0.5Px6
JS013006MV
Main PCB(7)
SET SCREW T3x6-2mm
JS053006TN
NUT M2x1.2t
JN242012ZS
MIC STOPPER
XZZZ90008Z
MOUNTING SCREW BLACK
XZZZ90007Z
SET SCREW W5x10-1
JS015010WH
SET SCREW T3.5x8-2
JS013508TH
OUT-TOOTH WASHER 5.5x10x0.3tmm
JW315510CN
IN-TOOTH WASHER 4x8x0.3tmm
JW324008CN
FIBER WASHER
XZZZ90188Z
Copyright © 2004 CBTricks.com
