Galaxy
DX Radios DX66V
Main PCB (EPT360014B) (EPT360014C)
Connectors
Ref# |
Bd Loc |
Description |
MFR.
Part No.
J101 |
PCB CONNECTOR/S 4P T PH=2.5(WHITE) |
EX07N41343 |
J101 |
WIRE CONNECTOR/H 4P 160MM |
EX07N41355 |
J102 |
PCB CONNECTOR/S 2P T PH=2.5(WHITE) |
EX07N41330 |
J102 |
WIRE CONNECTOR/H 2P L=180MM |
EX07N48041 |
J103 |
PCB CONNECTOR/S 12P T PH=2.5 WHITE |
EX07N41309 |
J103 |
WIRE CONNECTOR/H 12P |
EX07N48103 |
J104 |
EX07N41343 |
J104 |
EX07N41355 |
J105 |
PCB CONNECTOR/S 3P T PH=2.5(WHITE) |
EX07N41227 |
J106 |
EX07N41227 |
J107 |
EX07N41330 |
J108 |
PCB CONNECTOR/S 14P TPH=2.5 WHITE |
EX07N41369 |
J108 |
WIRE CONNECTOR/H 14P |
EX07N48104 |
J109 |
EX07N41330 |
J109 |
EX07N48041 |
ECHO(J2) |
WIRE CONNECTOR/H 3P L=120MM |
EX07N48192 |
Wire
Ref#
Description |
MFR.
Part No.
LEAD WIRE #26 50MM BLACK 5:5 |
WL0005005Z |
LEAD WIRE #26 60MM RED 5:5 |
WL0206005Z |
LEAD WIRE #26 50MM RED 5:5 |
WL0205005Z |
LEAD WIRE #26 120MM RED 5:5 |
WL0212005Z |
(SLIDE SW)-D113 |
LEAD WIRE #26 150MM BLUE 5:15 |
WL0615004Z |
R/SW-9 |
LEAD WIRE #26 60MM ORANGE 5:5 |
WL0306005Z |
R210-211 |
LEAD WIRE #26 150MM YELLOW 15:15 |
WL0415009Z |
J62-TR54 |
LEAD WIRE #26 150MM RED 15:15 |
WL0215009Z |
J15-G |
LEAD WIRE #26 170MM WHITE 15:15 |
WL0917009Z |
J10-G |
LEAD WIRE #26 200MM GREEN 15:15 |
WL0520009Z |
AMP-G |
LEAD WIRE #26 200MM RED 15:15 |
WL0220009Z |
L29-SPK |
LEAD WIRE #26 250MM VIOLET 15:15 |
WL0725009Z |
L30-PA |
LEAD WIRE #26 250MM WHITE 15:15 |
WL0925009Z |
L29-SPK |
WL0725009Z |
R212-VR12 |
LEAD WIRE #26 50MM BLUE 15:4 |
WL0605009Z |
R275-G |
WL0725009Z |
R275-G |
LEAD WIRE #26 200MM VIOLET 15:15 |
WL0720009Z |
Jumpers
Ref# |
Bd Loc |
Description |
MFR.
Part No.
J3 |
JUMPER WIRE 7x15x7mm |
WX01070715 |
J3 |
TUBE 1.2x13mm |
WX0012013A |
J4 |
JUMPER WIRE 7x30x7mm |
WX01070730 |
J5 |
WX01070715 |
J5 |
TUBE 1.2x13mm |
WX0012013A |
J6 |
JUMPER WIRE 7x6x7mm |
WX01070706 |
J7 |
WX01070715 |
J8 |
JUMPER WIRE 7x5x7mm |
WX01070705 |
J9 |
TUMPER WIRE 7X9X7mm |
WX01070709 |
J10 |
TUBE 1.2x15mm |
WX0012015A |
J12 |
JUMPER WIRE 7x20x7mm |
WX01070720 |
J13 |
JUMPER WIRE 7x8x7mm |
WX01070708 |
J14 |
JUMPER WIRE 7x12x7mm |
WX01070712 |
J18 |
WX01070708 |
J19 |
JUMPER WIRE 7x25x7mm |
WX01070725 |
J20 |
WX01070715 |
J21 |
JUMPER WIRE 7x35x7mm |
WX01070735 |
J22 |
WX01070708 |
J23 |
WX01070725 |
J25 |
WX01070709 |
J26 |
WX01070715 |
J27 |
WX01070715 |
J28 |
JUMPER WIRE 7x14x7mm |
WX01070714 |
J29 |
WX01070720 |
J30 |
WX01070706 |
J31 |
JUMPER WIRE 7x7x7mm |
WX01070707 |
J32 |
WX01070715 |
J33 |
WX01070707 |
J35 |
WX01070706 |
J37 |
JUMPER WIRE 7x22x7mm |
WX01070722 |
J38 |
WX01070714 |
J39 |
WX01070712 |
J40 |
WX01070708 |
J41 |
WX01070714 |
J42 |
WX01070708 |
J43 |
WX01070708 |
J44 |
WX01070706 |
J45 |
WX01070708 |
J46 |
WX01070712 |
J49 |
WX01070705 |
J50 |
WX01070706 |
J51 |
WX01070709 |
J52 |
WX01070706 |
J53 |
JUMPER WIRE 7x10x7mm |
WX01070710 |
J54 |
WX01070705 |
J57 |
WX01070712 |
J58 |
WX01070710 |
J59 |
JUMPER WIRE 7x18x7mm |
WX01070718 |
J60 |
WX01070708 |
J61 |
WX01070708 |
J63 |
WX01070708 |
J65 |
WX01070710 |
J66 |
WX01070705 |
J67 |
WX01070708 |
J68 |
WX01070709 |
J69 |
WX01070707 |
J71 |
WX01070707 |
J72 |
WX01070710 |
J73 |
WX01070707 |
J74 |
WX01070710 |
J75 |
WX01070705 |
J76 |
WX01070712 |
J79 |
WX01070705 |
J80 |
JUMPER WIRE 7x13x7mm |
WX01070713 |
J83 |
WX01070705 |
J85 |
WX01070710 |
J86 |
WX01070707 |
J87 |
WX01070708 |
J88 |
WX01070706 |
J89 |
WX01070705 |
J91 |
WX01070705 |
J92 |
WX01070706 |
J94 |
WX01070712 |
J95 |
WX01070708 |
J99 |
WX01070705 |
J100 |
WX01070705 |
J102A |
D2
WX01070710 |
R80 |
WX01070712 |
R139 |
JUMPER WIRE 7x4x7mm |
WX01070704 |
R156-J10 |
WX01070708 |
R157 |
JUMPER WIRE 7x3x7mm |
WX01070703 |
R233 |
WX01070710 |
R275 |
WX01070703 |
C93 |
WX01070704 |
C96 |
WX01070704 |
C111 |
WX01070704 |
D18 |
WX01070715 |
D19 |
WX01070715 |
D39 |
WX01070703 |
D57 |
WX01070703 |
D74 |
WX01070706 |
FL3 |
WX01070715 |
TR13 |
WX01070703 |
TP7-TP8 |
WX01070720 |
JTP7-TP8 |
WX01070725 |
TP7-TP9 |
WX01070713 |
IC3-C119 |
WX01070715 |
J11-C198 |
WX01070715 |
