Galaxy DX Radios DX66V
PLL Alignment
See Required test equipment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
10.240 MHz PLL REFERENCE:
RX Mode, AM,
Freq. to 26.965MHz Band E
Fine and coarse clarifier control to center detent.
Connect Frequency counter to IC5 Pin 4.
Check for 10.2400MHz ±200 Hz. If tolerance is beyond this, replace
X1 (10.240MHz).
VCO BUFFER:
RX Mode, AM,
Connect scope to TP3 (top bare lead of R74)
L18
Adjust for max. RF (0.80V p-p typical).
Connect scope to L22 secondary (bare lead of L50 ).
L22
Adjust for max. RF (2.0V p-p typical)
VCO:
RX Mode, AM,
Connect DC voltmeter to TP2 (top bare lead of R116)
L17
Adjust for 3.20 VDC ±0.1 Vdc.
Recheck at 25.165MHz for approx 2.0V. and 28.755MHz for approx 6.0V.
PLL OFFSET OSCILLATOR:
RX Mode, AM,
Modes as indicated.
Connect Frequency Counter to TP3 (top bare lead of R74).
L20
AM: Adjust for 16.2700MHz ±20 Hz.
FREQUENCY COUNTER:
Set mode to AM
VC1 on Counter PCB
Adjust VC1 on counter PCB for 26.965Mhz on display.
Copyright © 1998,1999,2000, 2001 CBTricks.com
