Galaxy DX Radios DX73V
DX73 Channel Select Board
(EPT077V30Z)
Trace Layout
Schematic Diagram
Top View
Bottom View
Ref. No.
Description
MFR. Part No.
  Channel Sel. P.C.B. 89x81x1.6tmm
EPT077V30Z
Channel Sel. P.C.B. Complete with Components
#MT-140R-P02
Ref. No.
Description
MFR. Part No.
R301
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R302
RCY011024Z
R303
RCY011024Z
R304
RCY011024Z
R305
RCY011024Z
R306
RCY011024Z
R307
RCY011024Z
R308
RCY011024Z
R309
RCY011024Z
R310
RCY011024Z
R311
RCY011024Z
R312
RCY011024Z
R313
RCY011024Z
R314
RCY011024Z
R315
CHIP/F/R (SMD) 470K OHM 0.1W
RCY014744Z
R316
CHIP/F/R (SMD) 1M OHM 0.1W
RCY011054Z
R317
RCY011054Z
R318
CHIP/F/R (SMD) 10M OHM 0.1W
RCY011064Z
R319
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R320
RCY014734Z
R321
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R322
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R323
RCY011034Z
R324
RCY014734Z
R325
RCY014734Z
R326
RCY014744Z
R327
RCY014734Z
R328
RCY014734Z
R329
RCY014734Z
R330
RCY014734Z
R331
RCY014734Z
R332
RCY014734Z
R333
RCY014734Z
R334
RCY014734Z
R335
RCY014734Z
R336
RCY014734Z
R338
RCY011024Z
R339
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
Ref. No.
Description
MFR. Part No.
C301
CHIP/C (SMD) 0.1UF 25WV Z Y5V
CK2104AB7R
C302
E/C 100UF 16WV Z H=5MM
CEM161077Z
C303
CHIP/C (SMD) 0.01UF 50WV M Z5U
CK1103AB6U
C304
CK1103AB6U
C306
CEM161077Z
C307
E/C 47UF 16WV Z
CEM164767Z
C308
CK2104AB7R
C309
CHIP/C (SMD) 0.47UF 25WV Z Y5V
CK2474AB7R
C310
CK1103AB6U
C311
CHIP/C (SMD) 0.22UF 50WV Z Y5V
CK1224AB7R
C312
CK1224AB7R
C313
CK1103AB6U
C314
CK1103AB6U
C315
CK1103AB6U
Ref. No.
Description
MFR. Part No.
IC301
I.C. (SMD) TC4511BF 16PIN
YNTA04511F
IC302
YNTA04511F
IC303
I.C. (SMD) 74HC374A 20PIN
YNTA74374A
IC304
YNTA74374A
IC305
I.C. NMC27C64Q-20
ENNS27C64Q
IC305
IC SOCKET 28PIN
EX07N48448
IC306
I.C. (SMD) AN8005M-E2 3PIN
YNMA08005M
IC307
I.C. (SMD) 4011 14PIN
YNXY04011Z
Ref. No.
Description
MFR. Part No.
Q301
T/R (SMD) RN2403-TE85L
TYZRN2403Z
Q302
TYZRN2403Z
Q303
T/R (SMD) RN1403-TE85L
TYZRN1403Z
Ref. No.
Description
MFR. Part No.
D302
DIODE MA27T-A
EDMA00027T
D303
DIODE (SMD) 1SS181-TE85L
EDSS00181Y
D304
DIODE (SMD) 1SS355
EDSS00355Y
D305
DIODE (SMD) 1SS355
EDSS00355Y
D306
DIODE (SMD) 1SS355
EDSS00355Y
D307
DIODE (SMD) 1SS184-TE85L
EDSS00184Y
D308
EDSS00184Y
D309
EDSS00184Y
D310
EDSS00184Y
D311
EDSS00184Y
D312
DIODE (SMD) 1SS355
EDSS00355Y
D313
EDSS00184Y
D314
DIODE (SMD) 1SS355
EDSS00355Y
D316
EDSS00184Y
D317
EDSS00184Y
Ref. No.
Description
MFR. Part No.
ROTARY SW GPS-0501
EWRT32000S
Ref. No.
Description
MFR. Part No.
J301
PCB CONNECTOR/S 8P PH=2MM
EX07W48829
J301
WIRE CONNECTOR/H 8P L=150MM PH=2MM
EX07W48856
J302
PCB CONNECTOR/S 7P PH=2MM
EX07W48828
J302
WIRE CONNECTOR/H 7P L=150/200 PH=2
EX07W48855
J303
PCB CONNECTOR/S 5P PH=2MM
EX07W48826
J303
WIRE CONNECTOR/H 5P L=100MM PH=2MM
EX07W48821
J304
PCB CONNECTOR/S 10P PH=2MM
EX07W48831
J304
WIRE CONNECTOR/H 10P L=150MM PH=2MM
EX07W48823
J305
PCB CONNECTOR/S 3P PH=2MM
EX07W48824
J305
WIRE CONNECTOR/H 3P L=200MM PH=2MM
EX07W48836
J306
PCB CONNECTOR/S 12P
EX07N48767
CN3-J306
WIRE CONNECTOR/H 12P L=100MM PH=2MM
EX07W49252
J307
PCB CONNECTOR/S 12P
EX07N48150
CN4-J307
WIRE CONNECTOR/H 12P L=120MM PH=2MM
EX07W49253
Copyright © 1998,1999,2000,2002 CBTricks.com
