Galaxy DX Radios DX73V
Chassis & Mechanical
Ref. No.
Description
MFR. Part No.
MAIN P.C.B. EPT360014C Complete
#MT-140R-P01
Ref. No.
Description
MFR. Part No.
STOPPER
UDT360003Z
HANDLER
MT3600030S
MIC STOPPER
XZZZ90008Z
MOUNTING SCREW M5x0.8Px11(BLACK)
XZZZ90007Z
SET SCREW W5x10-1
JS015010WH
SET SCREW T3.5x8-2
JS013508TH
OUT-TOOTH WASHER 5.5x10x0.3tmm
JW315510CN
IN-TOOTH WASHER 4x8x0.3tmm
JW324008CN
CR
FRONT PANEL
PTDX55010A
Counter
ACRY WINDOW ORANGE
PT2100030B
CH
DISPLAY WINDOW
PTDX55020A
FRONT CHASSIS
MTDX55033X
LED 3MM RED/GREEN
EX01N40004
SET CHASSIS
MT3001021M
TOP HOUSING
MT3600061X
BOTTOM HOUSING
MT3600071X
Ref. No.
Description
MFR. Part No.
Vol-SO
VR 50KA/50KB/SW
RV50303433
ECHO-ENC
VR 50KA/50KB/SW
RV50303433
DIM-POR
V/R 1KB/1KA W/SW
RV10203590
SWR CAL-CLAR
V/R 1KB/1KA W/SW
RV10203590
MIC-RF
VR 1KB/1KA BW/SW
RV10203514
MODE SW
ROTARY SW 6N
EWRT32038S
C/C 68PF 50WV CH J
CC0506804A
BAND SW
ROTARY SW 8N
EWRT32077S
ROTARY SW
KNOB (A-1)
PT3600101A
ROTARY SW
D SPRING A #6600
MT3600080T
DUAL VR(INNER)
KNOB B-1
PT3600110A
DUAL VR(INNER)
D SPRING B #7800
MT3600090T
SINGLE VR
KNOB C-1
PT3600120A
DUAL VR (OUTER)
KNOB D-1
PT3600130A
DUAL VR(OUTER)
D SPRING D #8500
MT3600100T
KNOB WASHER
PT3600090A
Ref. No.
Description
MFR. Part No.
SW x1
DIODE 1N4148
ED1N04148Z
SW x1
ZENER DIODE 5.1V 0.5W
EDZD05519Z
METER + SW
DIODE 1N4148
ED1N04148Z
Ref. No.
Description
MFR. Part No.
PCB BRACKET
MT3001010S
T&B HOUSING
SHIELD CLOTH 10x170x0.3t
LZZZ60082Z
CLAMP 100MM
GZZZ50000Z
FOAM 11x30x15t
XZZZ90021Z
COUNTER
FOAM 8x12x34mm
XZZZ90005Z
SOLDER PLATE
XZZZ90098Z
Ref. No.
Description
MFR. Part No.
EVRP PCB(2)
SET SCREW T3x8-2 STEEL
JS013008TH
SINK(2)
JS013008TH
FRONT PANEL(4)
SET SCREW M3x0.5Px6
JS033006MN
CH(2)
SET SCREW M3x0.5Px6
JS053006MN
FRONT(2)
SET SCREW M3x0.5Px6
JS053006MN
T&B(08)
SET SCREW M3x0.5Px6
JS053006MN
ECHO(2)
SET SCREW M3x0.5Px6
JS053006MN
MAIN PCB(7)
SET SCREW T3x6-2
JS053006TN
SPK(4)
SET SCREW M3x0.5Px8
JS053008MN
SPK
NUT WITH WASHER M3x3.5t
JN263035ZS
Ref. No.
Description
MFR. Part No.
SIGNAL METER P-48U-9014
EX03N40472
PA - M-
LEAD WIRE #26 100MM BLACK 5:5
WL0010005Z
M+
LEAD WIRE #26 (UL)100MM RED 5:5
WL0210005Z
M+
LEAD WIRE #26 (UL) 150MM ORANGE 5:5
WL0315005Z
Ref. No.
Description
MFR. Part No.
DC CORD W/FUSE SOCKET
WA0012185A
FUSE 16V 4A
EX02N40008
DC SOCKET
DC SOCKET HOLDER
MT3600050X
DC(2)
SET SCREW M3x0.5Px8
JS053008MN
DC x2
C/C 0.01UF 50WV SL Z
CC0501037L
DIODE LT6A400
EDLT6A400Z
L503
CHOKE COIL 0.47UH
ECCHK16000
TUBE 1.2x15mm BLACK
WX0012015A
L504
CHOKE COIL 0.47UH
ECCHK16000
TUBE 1.2x15mm BLACK
WX0012015A
ANT SOCKET WITH TEETH WASHER
EX06T41019
Ref. No.
Description
MFR. Part No.
J101
WIRE CONNECTOR/H 4P 160MM
EX07N41355
J102
WIRE CONNECTOR/H 3P
EX07N48300
J102
WIRE CONNECTOR/H 2P L=180MM
EX07N48041
J103
WIRE CONNECTOR/H 12P
EX07N48103
J104
EX07N41355
J106
WIRE CONNECTOR/H 3P L=140MM
EX07N48192
J108
WIRE CONNECTOR/H 14P
EX07N48104
J109
EX07N48041
MIC
EX07N48192
Ref. No.
Description
MFR. Part No.
NB+ (2)
LEAD WIRE #26 (UL) 50MM RED 5:5
WL0205005Z
VOL - NB
LEAD WIRE #26 120MM RED 5:5
WL0212005Z
E-TONE
WL0210005Z
E-TONE
LEAD WIRE #26 100MM YELLOW 5:5
WL0410005Z
E-TONE
LEAD WIRE #26 100MM WHITE 5:5
WL0910005Z
8 BAND SW
LEAD WIRE #26 (UL) 120MM BLACK 5:5
WL0012005Z
SWR-CAL S/W CAL SW
LEAD WIRE #26 (UL) 50MM BLACK 5:5
WL0005005Z
SWR CAL
LEAD WIRE #26 80MM BLUE 5:5
WL0608005Z
M- - SWR CAL
LEAD WIRE #26 170MM BLACK 5:5
WL0017005Z
M+ - SWR CAL
WL0315005Z
B+
LEAD WIRE #26 (UL) 150MM RED 5:5
WL0215005Z
DW
LEAD WIRE #26 120MM VIOLET 5:5
WL0712005Z
R244 - MIC PIN 4
LEAD WIRE #26 150MM GREEN 5:5
WL0515005Z
LEAD WIRE #26 (UL) 50MM ORANGE 5:5
WL0305005Z
Copyright © 2002 CBTricks.com
