Galaxy DX Radios DX77HML
Chassis Parts
Ref#
Description
MFR. Part No.
D88
DIODE MV-1Y
EDMV00001Y
D89
DIODE MV-1Y
EDMV00001Y
D112
DIODE MV-1Y
EDMV00001Y
ANT JACK
EX06T41019
ANT(1)
JUMPER WIRE 7x50mm x7
WX01070750
DC JACK 3P
EX06T40007
DC SOCKET HOLDER
MT3600050X
SET SCREW M3x0.5Px8 PCS 1 DC(2)
JS053008MN
DC CORD W/FUSE SOCKET
WA0012185A
DIODE LT6A400
EDLT6A400Z
DC(2)
C/C 0.01UF 50WV SL Z
CC0501037L
Rear Chassis
HEAT SINK
MM7878041B
Heat Sink(2)
SET SCREW T3x8-2
JS013008TN
SET CHASSIS
MT3001024M
DC B+ PCB 45.5x11.5x1.6
EPT120060A
SLIDE SW 3N
EWSL31000S
SLIDE SW 2N
EWSL31001S
TONE(2)
SET SCREW M2x0.4Px4
JS052004MN
CH9(2)
SET SCREW M2x0.4Px4
JS052004MN
WB/ANL SW(2)
SET SCREW M2x0.4Px4
JS052004MN
SWR SW(2)
SET SCREW M2.6x0.45Px5
JS052605MN
MASK PLATE(SW)
XZZZ90296A
SPEAKER 8ohm 3W 3.5in
ES300835SQ
SPEAKER(4)
SET SCREW M3x0.5Px8
JS053008MN
SPEAKER(4)
NUT WITH WASHER M3x3.5t
JN263035ZS
SIGNAL METER L=250mm
EX03N40407
METER HOLDER
PT3600080A
TUBE PCS 3.3x15mm 1 LAMP
WX0033015B
FRONT PANEL
PT148N010A
E-TONE
V/R 50KA/50KB W/SW
RV50303433
MIC GAIN-RF GAIN
V/R 1KB/1KA
RV10203345
FINE-COARSE
V/R 20KB/1KB
RV20303555
VOL-SQ
V/R 50KB/50KA/SW
RV50303344
ROTARY SW 6N
EWRT32038S
ROTARY SW SRRN252N08-RR (5N)
EWRT32060S
CH
KNOB (A-1)
PT3600101A
Inner
KNOB B-1(CHROM)
PT3600110A
Single
KNOB C-1
PT3600120A
Outer
KNOB D-1(CHROM)
PT3600130A
D SPRING A #6600
MT3600080T
D SPRING B #7800
MT3600090T
D SPRING D #8500
MT3600100T
KNOB WASHER
PT3600090A
TOP HOUSING
MT3600061X
BOTTOM HOUSING
MT3600071X
FRONT CHASSIS
MT3600010S
CHANNEL BRACKET
MT3600041S
ID PLATE DX-77HML
BT0148010H
GALAXY
MIC NAME PLATE GALAXY
BT2100020A
T&B HOUSING(4)
SHIELD CLOTH 10x88x0.3t
LZZZ60001Z
FOAM 15x30x11t
XZZZ90021Z
CLAMP GT-100M
GZZZ50000Z
CHASSIS(12)
SET SCREW M3x0.5Px6
JS053006MN
CH BKT(2)
SET SCREW T3x8-2 STEEL
JS013008TH
FRONT PANEL(4)
SET SCREW M3x0.5Px8
JS033008MN
MAIN PCB(5)
SET SCREW T3x6-2mm
JS053006TN
MICROPHONE ASSY,4P BLACK DMC507-012
EX04N40002
MIC STOPPER
XZZZ90008Z
HANDLER
MOUNTING SCREW BLACK
XZZZ90007Z
FIBER WASHER
XZZZ90188Z
FUSE 16V 7A
EX02N40210
SET SCREW W5x10-1
JS015010WH
SET SCREW T3.5x8-2
JS013508TH
OUT-TOOTH WASHER 5.5x10x0.3tmm
JW315510CN
IN-TOOTH WASHER 4x8x0.3tmm
JW324008CN
PCB STOPPER
XZZZ90006Z
Copyright © 1998,1999,2000, 2001 CBTricks.com
