Galaxy
DX Radios DX77HML
Transmitter
Alignment
See Required
test equipment
See Alignment
Locations
SETTINGS | CONNECTION |
ADJUST
ADJUST FOR |
Remove
TP7-TP9 Jumper PCB.
TX
FREQUENCY: Set mode to LSB |
Connect Frequency Counter to TP3 (top bare lead of R74). |
VR21
Key TX; Adjust for 16.2675MHz ±20 Hz. |
CARRIER
OSCILLATOR OFFSETS: TX Mode Freq. to 26.965MHz Band D |
Connect Frequency Counter to TP6 (top bare lead of R102). |
L28 |
LSB/TX mode: Adjust for 10.6975MHz ±20Hz.
L27
USB/TX
mode: Adjust for 10.6925MHz ±20 Hz. |
Connect Frequency Counter to (top bare lead of R151). |
L26
AM/TX mode: Adjust for 10.6950MHz ±20 Hz. | |
DRIVER BIAS: |
Connect
DC Ammeter between TP9 and TP8. |
VR11
Key TX adjust for 50-75mA. |
FINAL
BIAS: Band Switch & Ch. Selector to 26.965 MHz Ch.1 Band D Mode to USB MIKE GAIN at minimum. |
Connect DC Ammeter
between TP9 and TP7. |
VR10 |
Key TX & adjust VR10 & VR20 for minimum ( 0mA ) current. Next adjust VR10 for 50mA, then adjust VR20 for 100mA total. |
Replace
TP7-TP9 Jumper PCB.
RF AMP
CHAIN: Replace PCB shorting jumper. Set mode to AM. Set RF power switch to H. |
Connect wattmeter to ANT output. |
L43, L44,
L42, L40, L33 |
Key TX & adjust (in order) for maximum RF output . Recheck power at lowest & highest channels; readjust if necessary for balance across entire bandwidth. |
SSB
CARRIER BALANCE: Set mode to USB MIKE GAIN to minimum. |
VR7 |
Key TX; adjust for mim. carrier leakthrough on scope or wattmeter. Recheck on LSB mode. If necessary readjust for best balance of sideband suppression between LSB & USB |
SSB
ALC: Mode to USB. MIKE GAIN to maximum. Inject two-tone audio signal of 500 Hz and 2400 Hz, 30 mV (-18 dBm) at MIC jack. |
Connect
wattmeter to ANT output. audio generator to Mic Jack |
VR12
Key TX; adjust for 25 watts PEP. |
AM
CARRIER POWER HIGH: Set mode to AM, MIKE GAIN at minimum. RF Power to H. |
VR13 |
Key TX; adjust for
for 10 watts |
AM CARRIER
POWER MED: Set mode to AM, MIKE GAIN at minimum. RF Power to M. |
VR24
Key TX
& adjust for 4 watt output. (NOTE: VR24 is not marked on the PCB.) |
AM CARRIER
POWER LOW: Set mode to AM, MIKE GAIN at minimum. RF Power to L. |
VR16
Key TX & adjust for 1 watt output |
RF METER: Set mode to AM, MIKE GAIN at minimum. RF Power to H. |
VR8
Adjust so panel meter agrees with wattmeter. |
AMC: Mode to AM. MIKE GAIN to maximum. Inject audio signal of 1KHz 30mV (-18 dBm) at MIC jack. |
Connect modulation meter to ANT output. |
VR14
Adjust for 100% on modulation meter. |
FM DEVIATION: Mode to FM MIKE GAIN to maximum. Inject 1 KHz, 30 mV audio signal at mike jack. |
Connect deviation meter to ANT output. |
VR5
Adjust for 4.5KHz on deviation meter. |
