Galaxy DX Radios DX88HL
Chassis and Mechanical Parts
Ref. No.
Description
MFR. Part No.
TR41
TR 25A1869
T2SA01869
TR41
SEA SCREW M2x0.4Px8
JS052008MN
TR41
INSULATING RING
XZZZ90003Z
TR41(2)
INSULATING PLATE 12xl6x1t
XZZZ90064Z
TR43
TR 2SC2312C
T2SC02312C
TR43
SET SCREW M2x0.4Pxl2
JS052012MN
TR43
INSULATING RING
XZZZ90003Z
TR43
INSULATING PLATE 10xl4x1.55mm
XZZZ90358Z
TR43
NUT M2x1.2t
JN242012ZS
TR44
TR 2SC2166C
T2SC02166C
TR44
JS052012MN
TR44
INSULATING RING
XZZZ90003Z
TR44
XZZZ90358Z
TR44
NUT M2x1.2t
JN242012ZS
TR51
TR 25B754Y
T2SB00754Y
TR51
SET SCREW M2x0.4Px10
JS052010MN
TR51
INSULATING PLATE 18x13mm
XZZZ90020Z
TR56
TR 2SC2312C
T2SC02312C
TR56
JS052012MN
TR56
INSULATING RING
XZZZ90003Z
TR56
XZZZ90358Z
TR56
NUT M2x1.2t
JN242012ZS
IC8
I.C. TA7292AP (TOSHIBA)
ENTA07222A
IC8
SET SCREW M3x0.5Px6
JS013006MV
IC8
IC SHIELD B
LZZZ61008Z
D88
DIODE MV1Y
EDMV00001Y
D89
DIODE MV1Y
EDMV00001Y
D112
DIODE MV1Y
EDMV00001Y
Ref. No.
Description
MFR. Part No.
ANT JACK
EX06T41019
ANT(1)
JUMPER WIRE 7x50mmx7
WX01070750
DC JACK 3P
EX06T40007
DC SOCKET HOLDER
MT3600050X
DC(2)
C/C 0.01UF 50WV SL Z
CC0501037L
DIODE LT6A400
EDLT6A400Z
CHASSIS(2)
SET SCREW M3x0.5Px6
JS053006MN
SET CHASSIS W/NUT (MALAYSIA)
MT3001021M
MIC JACK
SOLDER PLATE
XZZZ90098Z
Ref. No.
Description
MFR. Part No.
VOL-SQ,E-TONE
V/R 50KB/50KA/SW
RV50303344
FINE-COARSE
V/R 20KB/1KB
RV20303555
MIC GAIN-RF GAIN
V/R 1KB/1KA
RV10203438
Transfer Potls
P.C.B. DC B+ 45X22X1.6
EPT120060Z
MODE
ROTARY SW SRRN252N08-RR (5N)
EWRT32060S
BAND
ROTARY SW 4N
EWRT32008S
ROTARY SW
KNOB (A-1)
PT3600101A
Dual VR(INNER)
KNOB B-1 (CHROM)
PT3600110A
Single VR
KNOB C-1
PT3600120A
Dual CR (OUTER)
KNOB B-1 (CHROM
PT3600130A
Flush Sty
PUSH BUTTON CHROM
PT2100020A
ROTATE SW
D SPRING A #6600
MT3600080T
DUAL VR (INNER)
D SPRING B #7800
MT3600090T
Ref. No.
Description
MFR. Part No.
SPEAKER 8 OHM 3W 3.5in
ES300835SQ
SIGNAL METER L=250mm
EX03N40407
METER HOLDER
PT3600080A
KNOB WASHER
PT3600090A
Counter
ACRY WINDOW ORANGE
PT2100030B
CH
DISPLAY WINDOW 30X23XI ORANGE
PT2100040B
TWN ECN
FRONT PANEL
PT2100060A
Ref. No.
Description
MFR. Part No.
FRONT CHASSIS
MT2100010A
CHANNEL BRACKET
MT3600041S
TOP HOUSING
MT3600061X
BOTTOM HOUSING
MT360007IX
OUT SIDE
HEAT SINK
MM7878041B
PCB BRACKET
MT3001010S
ID PLATE DX-88HL
BT2100011U
Top a Bottom Housing
SHIELD CLOTH 10x170x0.3t
LZZZ60082Z
CLAMP
GZZZ50000Z
SPONGE 80x42x3.5t
XZZZ90085Z
FOAM 15x30x11t
XZZZ90021Z
FOAM 8x12x34mm
XZZZ90005Z
FRONT CHASSIS
INSULATION SHEET 16x97x0.6tmm
XZZZ90309Z
BAND PCB(1),CH BKT(2)
SET SCREW T3x8-2 STEEL
JS013008TH
Front panel (4)
SET SCREW M3x0.5Px8
JS033008MN
DISPLAY PCB 41Z
SET SCREW M2.6x0.45Px6
JS052606MN
CHASSIS (8)BAND BRACKET(1)
SET SWREW M3x0.5Px6
JS053006MN
Main PCB(7)
SET SCREW T3x6-2mm
JS053006TN
HEAT SINK(2) PA PCB(1)
SET SCREW T3x8-2
JS013008TN
SP
NUT WITH WASHER M3x3.5t
JN263035ZS
FIBER WASHER 6x2.8x1t
JW306003GF
POWER x 2
CC0501037L
Ref. No.
Description
MFR. Part No.
J101
WIRE CONNECTOR/H 4P 160MM
EX07N41355
J102
WIRE CONNECTOR/H 3P L=120MM
EX07N48192
J103
WIRE CONNECTOR/H 12P
EX07N48103
J104
EX07N41355
J106
WIRE CONNECTOR/H 6P L=120MM
EX07N48191
J108
WIRE CONNECTOR/H 14P
EX07N48104
J109
WIRE CONNECTOR/H 2P L=180MM
EX07N48041
ECHO(J2)
WIRE CONNECTOR/H 3P L=140MM PH=2.5
EX07N48903
R189-ECHO(VR)
LEAD WIRE #26 220MM YELLOW 15:15
WL0422009Z
VOL SW-METER
LEAD WIRE #26 50MM BLACK 5:5
WL0005005Z
EPT210032Z-21Z
LEAD WIRE #26 150MM BLACK 5:5
WL0015005Z
EPT210040Z-32Z,BAND SW P IN 9-H/L BAND
LEAD WIRE #26 50MM RED 5:5
WL0205005Z
PA-BAND SW
LEAD WIRE #26 80MM ORANGE 5:5
WL0308005Z
VA-BAND SW
LEAD WIRE #26 80MM BLUE 5:5
WL0608005Z
MIC GAIN-VOL SW
LEAD WIRE #26 90MM BLACK 5:5
WL0009005Z
+l0KHZ-J1(BAND PCB)
LEAD WIRE #26 90MM RED 5:5
WL0209005Z
EPT210032Z-21Z
LEAD WIRE #26 170MM BLACK 5:5
WL0017005Z
VOL/SQ SW-FREQ.ON/OFF
LEAD WIRE #26 130MM RED 5:5
WL0213005Z
E-TONE - +10KHZ
LEAD WIRE .#26 70MM BLUE 5:5
WL0607005Z
COUNTER PCB(C10)-(U8 PIN1)
LEAD WIRE #26 60MM BROWN 5:5
WL0106005Z
Copyright © 1998,1999,2000, 2001 CBTricks.com
