Galaxy DX Radios DX88HL
Echo PCB (EPT0SSB50F) Board Layout
Trace Layouts
Schematic Diagram
Schematic Diagram
Resistors
Ref#
Description
MFR. Part No.
R1
10K OHM 0.1W
RCY011034Z
R2
33K OHM 0.1W
RCY013334Z
R3
10 OHM 0.1W
RCY011014Z
R4
47K OHM 0.1W
RCY014734Z
R5
33K OHM 0.1W
RCY013334Z
R6
33K OHM 0.1W
RCY013334Z
R7
2.2K OHM 0.1W
RCY012224Z
R13
33K OHM 0.1W
RCY013334Z
R14
47K OHM 0.1W
RCY014734Z
R15
33K OHM 0.1W
RCY013334Z
R16
10 OHM 0.1W
RCY011014Z
R17
4.7K OHM 0.1W
RCY014724Z
R18
22K OHM 0.1W
RCY012234Z
R20
47K OHM 0.1W
RCY014734Z
R21
100K OHM 0.1W
RCY011044Z
R22
33K OHM 0.1W
RCY013334Z
R23
10K OHM 0.1W
RCY011034Z
R24
10K OHM 0.1W
RCY011034Z
R26
10K OHM 0.1W
RCY011034Z
R27
1K OHM 0.1W
RCY011024Z
R28
470 OHM 0.1W
RCY014714Z
R29
4.7K OHM 0.1W
RCY014724Z
R30
10K OHM 0.1W
RCY011034Z
Capacitors
Ref#
Description
MFR. Part No.
C1
2.2uF 16WV
CK5225AA7R
C2
0.1Uf 25WV
CK2104AB7R
C3
0.1Uf 25WV
CK2104AB7R
C4
0.01uf 25WV
CK2103AB7R
C5
560PF 50WV
CK1561AB5A
C6
1uF 16WV
CK510AB7R
C10
0.1Uf 25WV
CK2104AB7R
C11
0.01uf 25WV
CK2103AB7R
C12
0.001uF 50WV
CK1102AB7L
C13
0.0015uF 50WV
CK1152AB7R
C14
0.001uF 50WV
CK1102AB7L
C16
0.1Uf 25WV
CK2104AB7R
C18
0.1Uf 25WV
CK2104AB7R
C19
.0047uF 50WV
CK1472AB6U
C20
1uF 16WV
CK510AB7R
C22
1uF 16WV
CK510AB7R
C23
0.01uf 25WV
CK2103AB7R
C25
1uF 16WV
CK5105ZZ7R
C26
330PF 50WV
CK1331AB5A
C27
47uF 16WV
CE0164767Z
C28
0.1Uf 25WV
CK2104AB7R
C29
0.1Uf 25WV
CK2104AB7R
C30
0.1Uf 25WV
CK2104AB7R
C31
1uF 16WV
CK510AB7R
C32
0.1Uf 25WV
CK2104AB7R
C33
0.1Uf 25WV
CK2104AB7R
C34
0.01uf 25WV
CK2103AB7R
C35
0.1Uf 25WV
CK2104AB7R
C36
0.1Uf 25WV
CK2104AB7R
C37
0.1Uf 25WV
CK2104AB7R
C38
0.1Uf 25WV
CK2104AB7R
C39
0.1Uf 25WV
CK2104AB7R
C40
0.1Uf 25WV
CK2104AB7R
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
IC NJM4558M 8PIN
YNJR04558M
IC2
IC ES56033S 16PIN
YNES56033S
Transistors
Ref#
Description
MFR. Part No.
Q1
TR 2SC2712GR
TY2SC2712G
Q3
TR 2SC2712GR
TY2SC2712G
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE 1SS355
EDSS00355Y
D2
DIODE 1SS355
EDSS00355Y
D3
ZENER DIODE 5.6V
EDZD05569Y
D4
DIODE 1SS355
EDSS00355Y
D5
DIODE 1SS355
EDSS00355Y
D6
DIODE 1SS355
EDSS00355Y
Connectors
Ref#
Description
MFR. Part No.
J1
PCB CONN/S 2PIN
EX07N48223
J2
PCB CONN/S 3PIN
EX07N41227
J3
PCB CONN/S 3PIN
EX07N41216
J6
PCB CONN/S 6PIN
EX07N48331
Copyright © 1998,1999,2000, 2001, 2002, 2003, 2004 CBTricks.com
