Galaxy DX Radios DX88HL
Band Board Layout
Schematic Diagram
Ref#
Description
MFR. Part No.
BAND PCB 82x50x1.6t
EPT004410Z
Resistors
Ref#
Description
MFR. Part No.
R6
C/F/R 47K OHM 1/4W U
RCU144734Z
R7
RCU144734Z
R8
RCU144734Z
R9
RCU144734Z
RA1
RESISTOR ARRAY 47K 8P
RCS0870014
RA2
RCS0870014
RA3
RCS0870014
Capacitors
Ref#
Description
MFR. Part No.
C1
E/C 220UF 10WV Z
CE0102277Z
C2
C/C 0.01UF 50WV SL Z
CCO501037L
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C.(MOTOROLA) MC14008BCP 16PIN
ENMC14008B
IC2
ENMC14008B
Diodes
Ref#
Description
MFR. Part No.
D4-36
DIODE IN4148
EDIN04148Z
Connectors
Ref#
Description
MFR. Part No.
J1
PCB CONNECTOR/S 12P T PH=2.5 (WHITE)
EX07N41309
J1
WIRE CONNECTOR/H 12P
EX07N48484
J2
PCB CONNECTOR/S 9P T PH=2.5(WHITE)
EX07N48083
J2
WIRE CONNECTOR/H 9P-9PL=150PH=2.5
EX07N48483
J3
PCB CONNECTOR/S 7P T PH=2.5(WHITE)
EX07N48167
J3
WIRE CONNECTOR/H 7P
EX07N48482
Jumper Wire
Ref#
Description
MFR. Part No.
J4
JUMPER WIRE 7x6x1
WX01070706
J5
JUMPER WIRE 7x15x7
WX01070715
J6
JUMPER WIRE 7x8x7
WX01070708
J7
JUMPER WIRE 7x7x7
WX01070707
J8
JUMPER WIRE 7x4x7
WX01070704
J9
JUMPER WIRE 7X9MMX7
WX01070709
J10
JUMPER WIRE 7x5x7
WX01070705
J11
JUMPER WIRE 7x4x7
WX01070704
J12
JUMPER WIRE 7X9MMX7
WX01070709
J13
JUMPER WIRE 7x8x7
WX01070708
J14
JUMPER WIRE 7X9MMX7
WX01070709
J15
JUMPER WIRE 7x13x7
WX01070713
J16
JUMPER WIRE 7x13x7
WX01070713
J17
JUMPER WIRE 7x11mmx7
WX01070711
J18
WX01070711
J19
JUMPER WIRE 7x10x7
WX01070710
J20
WX01070711
J22
JUMPER WIRE 7x3MMx7
WX01070703
J23
JUMPER WIRE 7x3MMx7
WX01070703
TR3
JUMPER WIRE 7x3MMx7
WX01070703
TR4
JUMPER WIRE 7x3MMx7
WX01070703
Copyright © 1998,1999,2000, 2001, 2002, 2003, 2004 CBTricks.com
