Galaxy DX Radios DX88HL
Frequency Counter Board Layout (EPT210010A) Very Early Production
Alignment Info
Schematic Diagram (gif)
EPT210010A Trace Layout
Ref#
Description
MFR. Part No.
COUNTER P.C.B EPT210010A
T-118U-P02
P.C.B.135X47.5X1.6
EPT210010A
Resistors
Ref#
Description
MFR. Part No.
R601
C/F/R F-TYPE 100 OHM 1/4W U
RCU141014Z
R602
C/F/R  F-TYPE 1K OHM 1/4W U
RCU141024Z
R603
RCU141024Z
R604
RCU141024Z
R605
RCU141024Z
R606
RCU141024Z
R607
C/F/R 470K OHM 1/4W U
RCU144744Z
R608
C/F/R 18K OHM 1/4W U
RCU141834Z
R609
C/F/R 82K OHM 1/4W U
RCU148234Z
R610
RCU141024Z
R612
RCU141014Z
R613
C/F/R 56 OHM 1/4W U
RCU145604Z
R614
C/F/R  F-TYPE 22K OHM 1/4W U
RCU142234Z
R615
C/F/R F-TYPE 10K OHM 1/4W U
RCU141034Z
R616
C/F/R 270 OHM 1/4W U
RCU142714Z
R617
RCU142234Z
R618
RCU141034Z
R619
RCU141034Z
R620
RCU142234Z
R621
C/F/R F-TYPE 100K OHM 1/4W U
RCU141044Z
R622
C/F/R 1.5M OHM 1/4W U
RCU141554Z
R623
RCU141014Z
R625
C/F/R 56 OHM 1/4W P
RCP145604Z
R626
C/F/R 560 OHM 1/4W U (copper side)
RCU145614Z
Trimmer Capacitors
Ref#
Description
MFR. Part No.
VC601
TRIMMER/C CV05E3001 30PF 5Q
CV050300AZ
VC602
CV050300AZ
VC603
TRIMMER/C CV05D2001 20PF 5Q
CV050200AZ
Capacitors
Ref#
Description
MFR. Part No.
C601
E/C 220UF 10WV Z
CE0102277Z
C602
M/C 0.001UF 50WV K
CM0501025Z
C603
C/C 0.047UF 50WV SL Z
CC0504737L
C604
CC0504737L
C605
C/C 5PF 50WV SL C
CC0500501L
C606
CC0504737L
C607
C/C 3PF 50WV CH C
CC0500301A
C608
E/C 220UF 10WV Z
CE0102277Z
C609
C/C 56PF 50WV SL J
CC0505604L
C610
E/C 1000UF 10WV Z
CE0101087Z
C611
C/C 56PF 50WV SL J
CC0505604L
C612
E/C 220UF 10WV Z
CE0102277Z
C613
CC0504737L
C614
CC0504737L
C615
E/C 220UF 10WV Z
CE0102277Z
C616
CC0504737L
C617
C/C 0.01UF 50WV SL Z
CC0501037L
C618
C/C 0.001UF 50WV SL Z
CC0501027L
C619
E/C 220UF 10WV Z
CE0102277Z
C620
CC0504737L
C621
CC0501037L
C622
C/C 120PF 50WV SL K
CC0501215L
C623
C/C 120PF 50WV CH K
CC0501215A
C624
C/C 560PF 50WV UJ K
CC0505615G
C625
C/C 56PF 50WV CH J
CC0505604A
C626
C/C 12PF 50WV CH J
CC0501204A
C627
CC0501037L
C628
C/C 15PF 50WV CH J
CC0501504A
C629
CC0504737L
C630
C/C 33PF 50WV CH J
CC0503304A
C631
C/C 68PF 50WV CH J
CC0506804A
C632
E/C 220UF 10WV Z
CE0102277Z
C633
CC0504737L
C634
CC0504737L
C635
CC0504737L
C636
C/C 5PF 50WV CH C (copper side)
CC0500501A
Integrated Circuits
Ref#
Description
MFR. Part No.
IC601
I.C.(TOSHIBA) TC4511BP   16PIN
ENTA04511B
IC602
I.C.(TOSHIBA) TC5032P    28PIN
ENTA05032P
IC603
I.C.(TOSHIBA) TC4572BP   16PIN
ENTA04572B
IC604
I.C.(TOSHIBA) TD6102P    9PIN
ENTA06102P
IC605
I.C.(HITACHI) HD10551    8PIN
ENHI10551Z
IC606
I.C.(TOSHIBA) TC4518BP   16PIN
ENTA04518B
IC607
I.C.(TOSHIBA) TA7310P    9PIN
ENTA07310P
IC608
I.C.(MOTOROLA) MC14060BCP 16PIN
ENMC14060B
IC609
I.C.(MOTOROLA) LM7808     3PIN
ENMC07808Z
Transistors
Ref#
Description
MFR. Part No.
TR601
T/R 2SA733P
T2SA00733P
TR602
T/R 2SA733P
T2SA00733P
TR603
T/R 2SA733P
T2SA00733P
TR604
T/R 2SA733P
T2SA00733P
TR605
T/R 2SA733P
T2SA00733P
TR606
T/R 9018G
TZZZ09018G
TR607
T/R 9018G
TZZZ09018G
TR608
T/R 9018G
TZZZ09018G
TR609
T/R 9018G
TZZZ09018G
Crystals
Ref#
Description
MFR. Part No.
X601
CRYSTAL HC-49U 2.67375MHZ 20PPM
EYCAD02673
X602
CRYSTAL HC-49U 3.2768MHZ 20PPM
EYCAD03276
Inductors
Ref#
Description
MFR. Part No.
T601
I.F.T.
ECIFT12012
T602
I.F.T.
ECIFT12070
Diodes
Ref#
Description
MFR. Part No.
D601
DIODE 1N4148
ED1N04148Z
D602
DIODE 1N4001
ED1N04001Z
D603
ZENER DIODE 2.4V 0.5W
EDZD05249Z
D604
DIODE 1N4148
ED1N04148Z
D605
DIODE 1N4148
ED1N04148Z
D606
DIODE 1N4001
ED1N04001Z
Connectors
Ref#
Description
MFR. Part No.
J10
PCB CONNECTOR/S 4P L TYPE
EX07N41283
J11
PCB CONNECTOR/S 16P L
EX07N41277
Jumper Wire
Ref#
Description
MFR. Part No.
J1
JUMPER WIRE 7x10x7mm
WX01070710
J2
JUMPER WIRE 7x12x7mm
WX01070712
J3
WX01070710
J4
WX01070710
J5
TUMPER WIRE 7x9x7mm
WX01070709
J6
JUMPER WIRE 7x7x7mm
WX01070707
J7
JUMPER WIRE 7x6x7mm
WX01070706
J8
JUMPER WIRE 7x7x7mm
WX01070707
J9
JUMPER WIRE 7x14x7mm
WX01070714
Copyright © 1998,1999,2000, 2001, 2002, 2003, 2004 CBTricks.com
