Galaxy DX Radios DX919
Channel Selector PCB Layout (EPT092920Z)
Trace Layout
Ref#
Description
MFR. Part No.
ROTARY SW EPT092920Z Complete with Components
#T-145W-P02
ROTARY SW PCB 80x49x1.6tmm (d)
EPT092920Z
Resistors
Ref#
Description
MFR. Part No.
R201
CHIP/F/R (SMD) 330 OHM 0.1W
RCY013314Z
R202
CHIP/F/R (SMD) 680 OHM 0.1W
RCY016814Z
R203
RCY016814Z
R204
RCY016814Z
R205
RCY016814Z
R206
RCY016814Z
R207
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
R210
RCY010004Z
R214
CHIP/F/R (SMD) 22K OHM 0.1W
RCY012234Z
R215
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R218
RCY010004Z
R219
RCY010004Z
R220
CHIP/F/R (SMD) 68K OHM 0.1W
RCY016834Z
R221
CHIP/F/R (SMD) 6.8K OHM 0.1W
RCY016824Z
Capacitors
Ref#
Description
MFR. Part No.
C201
CHIP/C (SMD) 0.1UF 50WV K
CK1104AB5X
C202
CK1104AB5X
Diodes
Ref#
Description
MFR. Part No.
D201
DIODE (SMD) 1SS355
EDSS00355Y
D202
DIODE (SMD) 1SS355
EDSS00355Y
D203
DIODE (SMD) 1SS355
EDSS00355Y
D204
DIODE (SMD) 1SS355
EDSS00355Y
D205
DIODE (SMD) 1SS355
EDSS00355Y
D206
DIODE (SMD) 1SS355
EDSS00355Y
D207
DIODE (SMD) 1SS355
EDSS00355Y
D208
DIODE (SMD) 1SS355
EDSS00355Y
D209
DIODE (SMD) 1SS355
EDSS00355Y
D210
DIODE (SMD) 1SS355
EDSS00355Y
D211
DIODE (SMD) 1SS355
EDSS00355Y
D212
DIODE (SMD) 1SS355
EDSS00355Y
D213
DIODE (SMD) 1SS355
EDSS00355Y
D214
DIODE (SMD) 1SS355
EDSS00355Y
D215
DIODE (SMD) 1SS355
EDSS00355Y
D216
DIODE (SMD) 1SS355
EDSS00355Y
D217
DIODE (SMD) 1SS355
EDSS00355Y
D218
DIODE (SMD) 1SS355
EDSS00355Y
D219
DIODE (SMD) 1SS355
EDSS00355Y
D220
DIODE (SMD) 1SS355
EDSS00355Y
D221
DIODE (SMD) 1SS181-TE85L
EDSS00181Y
D222
EDSS00181Y
D223
EDSS00181Y
D224
EDSS00181Y
D225
EDSS00181Y
D226
DIODE (SMD) 1SS355
EDSS00355Y
D227
DIODE (SMD) 1SS355
EDSS00355Y
D228
DIODE (SMD) 1SS355
EDSS00355Y
Transistors
Ref#
Description
MFR. Part No.
Q201
T/R (SMD) RN1403 -TE85L
TYZRN1403Z
Q202
QTYZRN1403Z
Q203
TYZRN1403Z
Q204
TYZRN1403Z
Q205
TRANSISTOR (SMD) RN2403-TE85L
TYZRN2403Z
Q206
TYZRN1403Z
Q207
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Connectors
Ref#
Description
MFR. Part No.
J201
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J202
PCB CONNECTOR/S 5P PH=2MM
EX07N48222
J203
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J204
PCB CONNECTOR/S 10P PH=2
EX07N48209
J205
C/F/R P-TYPE 0 OHM 1/16W P
RCP160004Z
J206
EX07N48223
Switch
Ref#
Description
MFR. Part No.
ROTARY SW GPS-0668
EWRT32059S
Copyright © 2003 CBTricks.com
