Galaxy DX Radios DX919
Dimmer PCB Layout (EPT092961Z)
Trace Layouts
Schematic
Ref#
Description
MFR. Part No.
DIMMER PCB EPT092961Z Complete with Components
#T-155-P06
DIMMER PCB 46x46x1.6tmm(d)
EPT092960Z
Resistors
Ref#
Description
MFR. Part No.
R604
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R605
CHIP/F/R (SMD) 3.3K OHM 0.1W
RCY013324Z
R606
CHIP/F/R (SMD) 47 OHM 1/4W
RCY144704Z
R607
RCY144704Z
Capacitors
Ref#
Description
MFR. Part No.
C601
CHIP/C (SMD) 0.1UF 50WV K
CK1104AB5X
C602
CHIP/C (SMD) 0.01UF 50WV K
CK1103AB5X
C607
CK1104AB5X
C608
CK1104AB5X
C609
CK1103AB5X
C610
CK1104AB5X
C611
CHIP/C (SMD) 4.7UF 16WV Z Y5V
CK5475AA7R
C612
CK1104AB5X
C613
CK1103AB5X
C614
CK1103AB5X
C615
CK1103AB5X
C616
CK1103AB5X
Transistors
Ref#
Description
MFR. Part No.
Q602
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q603
T/R (SMD) DTC124EUAT106
TYDTC124EA
Lamps
Ref#
Description
MFR. Part No.
LAMP
LAMP 0.05 12V
EX02N40230
Connectors
Ref#
Description
MFR. Part No.
J601
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J602
PCB CONNECTOR/S 5P PH=2MM
EX07N48222
J603
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
Hardware
Ref#
Description
MFR. Part No.
PCB
SET SCREW T3x6-2mm    (4)
JS053006TN
Copyright © 2003 CBTricks.com
