Galaxy
DX Radios DX919
Main PCB (EPT092912Z)
Crystals
Ref# |
Bd Loc |
Description |
MFR. Part No. |
X1 |
E2
CRYSTAL HC-49U 10.240MHZ 20PPM |
EYCAB10240 |
X3 |
F3
CRYSTAL HC-49U 15.480 MHZ 10PPM |
EYBAA15480 |
X4 |
F5
CRYSTAL HC-49U 10.6975MHZ 10PPM |
EYBAE10697 |
Filters
Ref# |
Bd Loc |
Description |
MFR. Part No. |
FL1 |
E2
CERAMIC FILTER CFW-455HT |
EFCFW455HT |
FL2 |
D2
CERAMIC FILTER SFE10.7MX RED |
EFCFE107MX |
Inductors
Ref# |
Bd Loc |
Description |
MFR. Part No. |
L1 |
C3
I.F.T. |
ECIFT12252 |
L2 |
E3
I.F.T. |
ECIFT12002 |
L3 |
E4
I.F.T. |
ECIFT12002 |
L5 |
B3
I.F.T. |
ECIFT12253 |
L6 |
B2
I.F.T. |
ECIFT12290 |
L7 |
B2
I.F.T. |
ECIFT12440 |
L8 |
C2
I.F.T. |
ECIFT12492 |
L9 |
C2
I.F.T. |
ECIFT12256 |
L10 |
C2
I.F.T. |
ECIFT12256 |
L13 |
F1
BEAD COIL WBRH-3.5x6x0.8-U10 |
ECBAD18526 |
L14 |
E1
I.F.T. |
ECIFT12263 |
L15 |
D2
I.F.T. |
ECIFT12258 |
L16 |
F3
CHOKE COIL 22UH 2.4mm |
ECCHK16246 |
L20 |
G3
I.F.T. |
ECIFT12012 |
L23 |
F5
I.F.T. 113CN-6344Z |
ECIFT12016 |
L28 |
A4
SPRING COIL 0.8x6x8.5t |
ECSPG18075 |
L29 |
A4
ECSPG18075 |
L30 |
A4
SPRING COIL 0.8x6.5x7.5t |
ECSPG18003 |
L31 |
A3
SPRING COIL 0.8x6.5x7.5tmm |
ECSPG18365 |
L33 |
A3
CHOKE COIL 22UH |
ECCHK16070 |
L35 |
A2
SPRING COIL 0.8x3.5x7t |
ECSPG18001 |
L37 |
A1
CHOKE COIL 22UH |
ECCHK16070 |
L38 |
B1
RF COIL 25UH PCS |
ECRFZ10048 |
L39 |
B1
BEAD COIL RH3.5x6.0x0.8 AT F |
ECBAD18506 |
L40 |
B1
I.F.T. |
ECIFT12262 |
L41 |
A2
ECBAD18526 |
L42 |
C1
I.F.T. PCS |
ECIFT12440 |
L43 |
C2
I.F.T. |
ECIFT12265 |
L44 |
D1
I.F.T. |
ECIFT12255 |
L47 |
F1
CHOKE COIL 4.7UH 2.4mm |
ECCHK16176 |
L48 |
H1
CHOKE COIL 470UH |
ECCHK16096 |
L503 |
CHOKE COIL 0.47UH |
ECCHK16000 |
TUBE 1.2x15mm |
WX0012015A |
L504 |
LEAD WIRE #18 70MM BLACK 5:5 |
WH0007005Z |
T1 |
C6
CHOKE COIL 1.1MH EI-19 |
ECCHK16004 |
