Galaxy
DX Radios DX919
Receiver Alignment
See Alignment
Locations
SETTINGS | CONNECTION |
ADJUST
ADJUST FOR |
AM
Sensitivity: Set radio to CH 19 AM RX mode. Set RF GAIN fully clockwise. Set SQ fully counter-clockwise. Set VOL Control at 2 o’clock. |
Connect
AF VTVM or scope across speaker terminals. Connect RF SG to antenna jack. Frequency 27.185 MHz, 1uV. Mod 30%. |
(in
order)
L5,L6, L7,L8, L9,L10, L2,L3 |
Audio
Output > 2V S/N > 10 dB. Balance between CH 1 and CH 40 |
Set radio to CH 40
AM RX mode. Set radio to CH 1
AM RX mode. |
RF SG setting 27.405 MHz. 100uV. Mod 30% RF SG setting 26.965 MHz, 100uV. Mod 30%. |
L5,L6
For Balance Between CH 1 and CH 40. |
NB
Adjust: Set radio to CH 19 AM RX mode Set switch to NB/ANL position. |
RF SG setting 27.205 MHz, 100uV. Mod 30%. Connect Multi-meter to TP1 (D2 cathode). |
L1
DC Voltage to max.( > 2.0V ) |
AM Squelch: Set radio to CH 19 AM RX mode. Set SQ Control fully clockwise. RF SG setting 27.185 MHz, 20mV. Mod 30%. |
VR4
Adjust very slowly until squelch just closes. | |
AM S-Meter: Set radio to CH 19 AM RX mode. RF SG setting 27.185 MHz, 100uV. Mod 30%. |
VR1
For a reading of "9" on the "S" scale. |
