Galaxy
DX Radios DX919
Transmitter Alignment
See Alignment
Locations
SETTINGS | CONNECTION |
ADJUST
ADJUST FOR |
AM OSC: Set radio to CH 19 AM TX mode. |
Connect Frequency Counter to TP5. |
L23
10.6950MHz ± 10Hz |
TX Power: Set radio to CH 19 AM TX mode. Set SWR/MOD/PWR Switch to PWR. |
Connect RF Power Meter
to antenna jack. |
L40,L42
L43,L44 |
MAX >
12W Balance Power Between CH1 and CH40. |
AM
TX High Power: Set radio to CH 19 AM TX mode. Set RF POWER fully clockwise. |
Same as above. |
VR14
3.8 W |
AM TX
Low Power: Set RF POWER fully counterclockwise. |
Same as above. |
VR18
0.3W ±0.2W |
RF
Power Meter: Set radio to CH 19 AM TX mode. Set RF POWER fully clockwise. Set SWR/MOD/PWR Switch to PWR position. |
VR9
For a needle reading of "4" on TX PWR scale. | |
AM Modulation: Set radio to CH 19 AM TX mode. Set MIC Gain fully clockwise. |
Connect AF
SG to microphone input. AF signal 30mV, 1 KHz to microphone. |
VR16
For a needle reading of 90% on the external modulation meter. |
AM Modulation
Meter: Set radio to CH 19 AM TX mode. Set MIC Gain fully clockwise. Set SWR/MOD/PWR Switch to MOD position |
VR15
For a needle reading of 90% on the modulation scale. |
