Galaxy
DX Radios DX929
CCHASSIS PARTS DX-929
Ref#
Description |
MFR. Part No. |
SPEAKER 8ohm 3W 3.5in |
ES300835SQ |
SPK(4) |
SET SCREW M3x0.5Px8 |
JS053008MB |
SPK(4) |
NUT WITH WASHER M3x3.5t |
JN263035ZS |
SPK |
RUBBER COVER |
QT7799010A |
ANT JACK |
EX06T41019 |
ANT JACKx2 |
SOLDER PLATE |
XZZZ90098Z |
DC JACK |
EX06T40007 |
DC(2) |
JS053008MN |
DIODE LT6A400 |
EDLT6A400Z |
DC(2) |
C/C 0.01UF 50WV SL Z |
CC0501037L |
DC SOCKET HOLDER |
MT3600050X |
DC CORD W/FUSE SOCKET |
WA0012185A |
FUSE 125V 4A |
EX02N40206 |
SIGNAL METER P-48U-9109 |
EX03N40482 |
PA |
EAR JACK 3.5mm |
EX06N41045 |
EXP SP |
EAR JACK 3.5mm |
EX06N41045 |
MIC (RANGER) SRA-112 (#R-114)(4P) |
EX04N40704 |
MIC JACK 4P |
EX06N41101 |
MIC JACK |
SOLDER PLATE |
XZZZ90098Z |
MECHANICAL: DX-929 |
#T-145W-P08 |
ID PLATE |
BT240N030A |
EL PLATE |
BT240N040A |
FRONT PANEL |
PT240N020A |
FRONT HOUSING |
PT240N030A |
DISPLAY WINDOW(CH) RED |
PTDX55020B |
DISPLAY BAR DX-949 |
PTDX55040A |
FRONT CHASSIS |
MT240N070X |
TOP HOUSING |
MT1200011K |
BOTTOM HOUSING |
MT1200210K |
CH KNOB TR-396 |
PT148N021A |
VR KNOB TR-396 |
PT148N031A |
OUTER KNOB |
PT148N090A |
INNER KNOB |
PT148N100A |
D SPRING A #6600 |
MT3600080T |
D SPRING B #7800 |
MT3600090T |
D SPRING D #8500 |
MT3600100T |
MOUNTING BRACKET |
MT1200090A |
HEAT SINK |
MM7878041B |
FOAM 15x30x11t |
XZZZ90021Z |
MASK PLATE(SW) |
XZZZ90296A |
FOAM 8x12x34mm |
XZZZ90005Z |
MOUNTING SCREW BLACK |
XZZZ90007Z |
MIC STOPPER |
XZZZ90008Z |
FIBER WASHER |
XZZZ90188Z |
INSULATING PLATE 12x16x1t |
XZZZ90064Z |
SHIELD CLOTH 10x170x0.3t |
LZZZ60082Z |
Front Panel |
SET SCREW M3x0.5Px6 |
JS033006MN |
CH(2) |
JS053006MN |
H/S(4) |
JS053006MN |
Panel(4) |
JS053006MN |
Back(4) |
JS053006MN |
PCB(4) |
JS053006MN |
T/H(4) |
JS053006MN |
B/H(4) |
JS053006MN |
SET SCREW W5x10-1 |
JS015010WH |
SET SCREW T3.5x8-2 |
JS013508TH |
OUT-TOOTH WASHER 5.5x10x0.3tmm |
JW315510CN |
IN-TOOTH WASHER |
JW324008CN |
I/M VX-129CN |
AT240N010A |
CLAMP GT-100M |
GZZZ50000Z |
