Galaxy DX Radios DX929
Dimmer / EL PCB Layout (EPT092961Z)
Trace Layouts
Schematic
Ref#
Description
MFR. Part No.
DIMMER PCB EPT092961Z
#T-145W-P06
METER P.C.B. 46x46x1.6tmm (d)
EPT092961Z
Resistors
Ref#
Description
MFR. Part No.
R601
CHIP/F/R (SMD) 12K OHM 0.1W
RCY011234Z
R602
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R603
CHIP/F/R (SMD) 15 OHM 1/4W
RCY141504Z
R604
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R605
CHIP/F/R (SMD) 3.3K OHM 0.1W
RCY013324Z
R606
CHIP/F/R (SMD) 47 OHM 1/4W
RCY144704Z
R607
RCY144704Z
R609
CHIP/F/R (SMD) 180K OHM 0.1W
RCY011844Z
R610
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R611
RCY011034Z
Capacitors
Ref#
Description
MFR. Part No.
C601
CHIP/C (SMD) 0.1UF 50WV K X7R
CK1104AB5X
C602
CHIP/C (SMD) 0.01UF 50WV K X7R
CK1103AB5X
C603
E/C (SMD) 47UF 16WV Z
CEY164767Z��
C604
E/C (SM.D) 100UF 25WV Z
CEY251077Z
C605
CHIP/C (SMD) 4.7UF 16WV� Z� Y5V
CK5475AA7R���
C606
CEY164767Z���
C607
CK1104AB5X
C608
CK1104AB5X
C609
CK1103AB5X
C610
CK1104AB5X
C611
CK5475AA7R���
C612
CK1104AB5X
C613
CK1103AB5X
C614
CK1103AB5X
C615
CK1103AB5X
C616
CK1103AB5X
C617
CHIP/C (SMD) 0.47UF 25WV Z Y5V
CK2474AB7R
C618
CEY251077Z
C619
CHIP/C (SMD) 1UF 16WV Z Y5V
CK5105AB7R
C620
CK1104AB5X
C621
CHIP/C (SMD) 0.047UF 50WV K X7R
CK1473AB5X
C622
T/C (SMD) 10UF 16WV M ('A'CASE)
CTY161066A
Inductors
Ref#
Description
MFR. Part No.
L601
CHOKE COIL (SMD) 470UH TE K
YCTLI4774E
L602
CHOKE COIL (SMD) 220UH TE K
YCTLI2274E
Transistors
Ref#
Description
MFR. Part No.
Q601
TRANSISTOR(SMD) 2SC2712GR-TE85L
TY2SC2712G
Q602
TY2SC2712G
Q603
T/R (SMD) DTC124EUAT106
TYDTC124EA
Integrated Circuits
Ref#
Description
MFR. Part No.
IC601
I.C. (SMD) SM8144BV-E2 8PIN
YNSN8144BV
Diodes
Ref#
Description
MFR. Part No.
D601
ZENER DIODE (SMD) RLZ5.1BT6-11
EDZD05519Y
D602
DIODE (SMD) 1N4148
ED1N04148Y
Lamps
Ref#
Description
MFR. Part No.
LAMP
LAMP 0.05 12V
EX02N40230
Connectors
Ref#
Description
MFR. Part No.
J601
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J602
PCB CONNECTOR/S 5P PH=2MM
EX07N48222
J603
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
Copyright © 2003 CBTricks.com
