Galaxy DX Radios DX929
VR PCB (VOL-SQ-OFF, POWER, DIMMER) (EPT092940Z)
Trace Layouts
Ref#
Description
MFR. Part No.
VR PCB EPT092940Z Complete with Components
#T-145W-P04
VR P.C.B. 88x32x1.6tmm (d)
EPT092940Z
Resistors
Ref#
Description
MFR. Part No.
R401
CHIP/F/R (S.M.D) 10K OHM 0.1W
RCY011034Z
Capacitors
Ref#
Description
MFR. Part No.
C401
CHIP/C (SMD) 0.001UF 50WV K X7R
CK1102AB5X
C402
CK1102AB5X
C403
CHIP/C (SMD) 0.01UF 50WV K X7R
CK1103AB5X
C404
CK1103AB5X
Inductors
Ref#
Description
MFR. Part No.
L401
BEAD FERRITE COIL WB-403025
YCBAD18581
L402
CHOKE COIL (SMD) 5.6UH TC J
YCTLI5653C
Transistors
Ref#
Description
MFR. Part No.
Q902
T/R (S.M.D.) DTA124EUAT106
TYDTA124EA
Potentiometers
Ref#
Description
MFR. Part No.
VR401
VR 50KB/50KA W/SW      (VOL-SQ-OFF)
RV50303522
POWER
VR 5KB
RV50203525
DIMMER
VR 5KB
RV50203525
Connectors
Ref#
Description
MFR. Part No.
J401
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J402
PCB CONNECTOR/S 5P PH=2MM
EX07N48222
J403
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J407
PCB CONNECTOR/S 3P T PH=2.5
EX07N41216
J408
EX07N48223
J409
PCB CONNECTOR/S 5P PH=2MM (WHITE)
EX07W48826
J410
EX07N48223
J411
EX07N48223
J413
EX07N48350
J414
PCB CONNECTOR/S 3P PH=2MM (WHITE)
EX07W48824
J415
EX07N48223
Copyright © 2003 CBTricks.com
