Galaxy
DX Radios DX939
MODULAR 002 P.C.B.�EPF000210Z
Trace Layout
Schematic Diagram
Ref# |
Description |
MFR. Part No. |
MODULAR 002A UHIC07A SUB |
#MF-002A |
MODULAR 002 PCB 26.5x12.5x1.0mm |
EPF000210Z |
Resistors
Ref# |
Description |
MFR. Part No. |
R1 |
CHIP/F/R (SMD) 10 OHM 0.1W |
RCY011004Z |
R2 |
CHIP/F/R (SMD) 10K OHM 0.1W |
RCY011034Z |
R3 |
CHIP/F/R (SMD) 100 OHM 0.1W |
RCY011014Z |
R4 |
RCY011034Z |
R5 |
RCY011034Z |
R6 |
CHIP/F/R (SMD) 560 OHM 0.1W |
RCY015614Z |
R7 |
CHIP/F/R (SMD) 3.3K OHM 0.1W |
RCY013324Z |
R9 |
CHIP/F/R (SMD) 220K OHM 0.1W |
RCY012244Z |
R10 |
RCY011004Z |
Capacitors
Ref# |
Description |
MFR. Part No. |
C1 |
T/C (SMD) 1UF 16WV M(25WV) 'A'CASE |
CTY161056Z |
C2 |
CHIP/C 0.01UF 50WV M Z5U K X7R |
CK1103AB6U |
C3 |
CHIP/C 390PF 50WV K SL J CH |
CK1391AB5L |
C4 |
CHIP/C 180PF 50WV K SL K CH |
CK1181AB5L |
C5 |
CHIP/C 10PF 50WV D CH |
CK1100AB2A |
C6 |
CK1100AB2A |
C7 |
CHIP/C 27PF 50WV J CH |
CK1270AB4A |
C8 |
CHIP/C 68PF 50WV J CH |
CK1680AB4A |
C10 |
CHIP/C 0.001UF 50WV Z SL K X7R |
CK1102AB7L |
Transistors
Ref# |
Description |
MFR. Part No. |
Q1 |
T/R (SMD) 2SC2712GR-TE85L |
TY2SC2712G |
Q2 |
T/R (SMD) 2SC3123-TE85L |
TY2SC3123Z |
Q3 |
TY2SC3123Z |
Diodes
Ref# |
Description |
MFR. Part No. |
D2 |
DIODE (SMD) 1SV217-TP |
ED1V00217Y |
IC Pin
Ref# |
Description |
MFR. Part No. |
IC PIN 022-1.0-S (WAKO) |
GZZZ50098Z |
