Galaxy DX Radios DX939
Frequency Counter PCB (EPT900043Z)
Trace Layouts
Ref# Description
MFR. Part No.
COUNTER PCB (DX-939) (VR DIM-C)
#MT-155E-P06
COUNTER PCB 62x34.5x1.6tmm(d)
EPT900043Z
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/F/R (SMD) 220 OHM 0.1W
RCY012214Z
R3
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R4
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R5
RCY014724Z
R6
CHIP/F/R (SMD) 330 OHM 0.1W
RCY013314Z
R7
RCY011034Z
R8
RCY011034Z
R9
RCY011034Z
R10
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R11
RCY011034Z
R12
RCY013314Z
R13
RCY011034Z
R14
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R15
CHIP/F/R (SMD) 39K OHM 0.1W
RCY013934Z
R16
CHIP/F/R (SMD) 47 OHM 0.1W
RCY014704Z
R17
RCY013314Z
R18
RCY012214Z
R19
CHIP/F/R (SMD) 1M OHM 0.1W
RCY011054Z
R20
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R21
RCY011014Z
R22
RCY011014Z
R23
RCY011014Z
R24
RCY011014Z
R25
RCY011014Z
R26
RCY011014Z
R27
RCY011014Z
R28
RCY011014Z
R29
RCY011014Z
R30
RCY011014Z
R31
RCY011014Z
R32
RCY011014Z
R33
RCY011014Z
R34
RCY011014Z
R35
RCY011014Z
R36
RCY011014Z
R37
RCY011014Z
R38
RCY011014Z
R39
RCY011014Z
R40
RCY011014Z
R41
RCY011014Z
R42
RCY011014Z
R43
RCY011034Z
R44
RCY011034Z
R45
RCY011034Z
R46
RCY011024Z
Capacitors
Ref#
Description
MFR. Part No.
C1
E/C 100UF 16WV H=5mm
CEM161077A
C2
CHIP/C 0.1UF 50WV Z F Y5V
CK1104AB7R
C3
CK1104AB7R
C4
CK1104AB7R
C5
CEM161077A
C7
CHIP/C 0.01UF 50WV M Z5U K X7R
CK1103AB6U
C8
CK1103AB6U
C9
CK1103AB6U
C10
CEM161077A
C11
CK1103AB6U
C12
CK1103AB6U
C13
CK1104AB7R
C14
CK1103AB6U
C15
CK1103AB6U
C16
CEM161077A
C17
CHIP/C 15PF 50WV J CH
CK1150AB4A
C19
CK1104AB7R
C20
CK1103AB6U
C21
CK1104AB7R
C22
CK1104AB7R
C23
CK1104AB7R
C24
CK1104AB7R
C25
CK1104AB7R
C26
CK1104AB7R
C27
CK1104AB7R
Ref#
Description
MFR. Part No.
VC1
TRIMMER/C (SMD) 20PF
CV038200AY
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
IC (JRC) (SMD) NJM78L05UA-TE1 3PIN
YNJR78L05Z
IC2
IC (PHILIPS) (SMD) 74HC161D 16PIN
YNPHHC161D
IC3
IC (RANGER) (SMD) HT48R50A-48 48PIN
YNRGFC04SP
Crystals
Ref#
Description
MFR. Part No.
X1
CRYSTAL HC-49/U 4.500MHz
EYCAP04500
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1SS355
EDSS00355Y
D2
DIODE (SMD) 1SS355
EDSS00355Y
D3
DIODE (SMD) 1N4148
ED1N04148Y
D4
DIODE (SMD) 1N4148
ED1N04148Y
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q2
TY2SC2712G
Q3
T/R (SMD) 2SC2714Y-TE85L
TY2SC2714Z
Q4
T/R (SMD) 2SA1162GR-TE85L
TY2SA1162G
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL (SMD) 100UH TF J
YCTLI1073F
Connectors
Ref#
Description
MFR. Part No.
CN1
PCB CONNECTOR/S 7P PH=2MM
EX07N48224
CN2
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
CN3
PCB CONNECTOR/S 12P PH=2 L=6.8mm
EX07N48927
CN4
EX07N48927
Hardware
Ref#
Description
MFR. Part No.
CRYSTAL
DISPLAY SPONGE 18x12MMx6T
XZZZ90092Z
Copyright © 2007 CBTricks.com
