Galaxy DX Radios DX939
Main PCB (EPT069611A)
Crystals
Ref#
Description
MFR. Part No.
X1
CRYSTAL HC-49U 10.240MHZ 20PPM
EYCAB10240
X3
CRYSTAL HC-49U 15.360MHZ 20PPM
EYCAA15360
X4
CRYSTAL HC-49U 10.6975MHZ 10PPM
EYBAE10697
Filters
Ref#
Description
MFR. Part No.
FL1
CERAMIC FILTER CFW-455HT
EFCFW455HT
FL2
CERAMIC FILTER SFE10.7MX RED
EFCFE107MX
Inductors
Ref#
Description
MFR. Part No.
L1
I.F.T.
ECIFT12252
L2
I.F.T.
ECIFT12002
L3
I.F.T.
ECIFT12002
L5
I.F.T.
ECIFT12253
L6
I.F.T.
ECIFT12290
L7
I.F.T.
ECIFT12440
L8
I.F.T.
ECIFT12492
L9
I.F.T.
ECIFT12256
L10
I.F.T.
ECIFT12256
L13
BEAD COIL WBRH-3.5x6x0.8-U10
ECBAD18526
L14
I.F.T. M292CNA-P1966Z
ECIFT12558
L15
I.F.T.
ECIFT12258
L16
CHOKE COIL 22UH 2.4mm
ECCHK16246
L20
I.F.T.
ECIFT12012
L23
I.F.T. 113CN-6344Z
ECIFT12016
L28
SPRING COIL 0.8x6.5x7.5t
ECSPG18003
L29
SPRING COIL 0.8x6x8.5t
ECSPG18075
L30
ECSPG18003
L31
SPRING COIL 1.0x6.5x7.5tmm
ECSPG18412
L35
SPRING COIL 0.8x3.5x7t
ECSPG18001
L38
RF COIL 25UH
ECRFZ10048
L39
ECBAD18526
L40
I.F.T.
ECIFT12262
L41
ECBAD18526
L42
I.F.T.
ECIFT12440
L43
I.F.T.
ECIFT12258
L44
I.F.T.
ECIFT12255
L46
CHOKE COIL 470UH
ECCHK16003
L47
CHOKE COIL 4.7UH 2.4mm
ECCHK16176
L48
CHOKE COIL 470UH
ECCHK16096
L503
BEAD COIL RH-7.75x13x4
ECBAD18585
R249
BEAD COIL RH3.5x6.0x0.8 AT
ECBAD18506
T1
CHOKE COIL 1.1MH (EI-19)
ECCHK16004
L503
LEAD WIRE #22 100mm RED 5:5
WJ0210005Z
L504
LEAD WIRE #22 70mm BLACK 5:5
WJ0007005Z
Copyright © 2007 CBTricks.com
