Galaxy DX Radios DX939
Transmitter Alignment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
AM OSC:
Set radio to CH 20 AM TX mode.
Connect Frequency Counter to TP5.
L23
10.6950MHz � 10Hz
TX Power:
Set SWR/MOD/PWR Switch to PWR.
Connect RF Power Meter to antenna jack.
L40,L42
L43,L44
Set for max. output
Balance Power Between CH1 and CH40.
Dvr/Final Gate Voltage:
Connect voltmeter to bare lead of L37.
Connect voltmeter to bare lead of L33.
VR12
VR10
Adjust for 3.75vdc
Adjust for 3.65vdc
AM TX High Power:
Set RF POWER fully clockwise.
VR14
6.0 watts
AM TX Low Power:
Set RF POWER fully counterclockwise.
VR18
2.0 watts
RF Power Meter:
Set SWR/MOD/PWR Switch to PWR position.
VR9
For a needle reading of "6" on TX PWR scale.
AM Modulation:
Set MIC Gain fully clockwise.
Connect AF SG to microphone input.
AF signal 30mV, 1 KHz to microphone.
VR16
For a needle reading of 100% on the external modulation meter.
AM Modulation Meter:
Set SWR/MOD/PWR Switch to MOD position
VR15
For a needle reading of 100% on the modulation scale.
Copyright © 2007 CBTricks.com
