Galaxy DX Radios DX93T
Channel Selector / Frequency Counter PCB (EPT091V31Z)
Part Layout Top View
Trace Layout Top View
Part Layout Bottom View
Trace Layout Bottom View
Parts List
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
R3
RCY010004Z
R3
CHIP/F/R (SMD) 2.2K OHM 0.1W
RCY012224Z
R4
RCY012224Z
R5
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R6
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R7
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R8
RCY014734Z
R9
CHIP/F/R (SMD) 330 OHM 0.1W
RCY013314Z
R10
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R11
RCY011014Z
R12
RCY011024Z
R12
RCY011014Z
R13
RCY011014Z
R13
RCY011024Z
R14
RCY011014Z
R14
RCY011024Z
R15
RCY011014Z
R16
RCY011014Z
R17
RCY011014Z
R18
RCY011014Z
R19
RCY011014Z
R20
RCY011014Z
R21
RCY011014Z
R22
RCY011014Z
R23
RCY011014Z
R24
RCY011014Z
R25
RCY011014Z
R26
RCY011014Z
R27
RCY011014Z
R28
RCY011014Z
R29
RCY011014Z
R30
RCY011014Z
R31
CHIP/F/R (SMD) 470 OHM 0.1W
RCY014714Z
R32
CHIP/F/R (SMD) 33K OHM 0.1W
RCY013334Z
R33
RCY011034Z
R35
CHIP/F/R (SMD) 22K OHM 0.1W
RCY012234Z
R36
RCY012234Z
R37
RCY012234Z
R38
RCY012234Z
R39
RCY012234Z
R40
RCY012234Z
R41
RCY011034Z
R43
RCY011024Z
R44
RCY014734Z
R45
RCY014734Z
R46
RCY012234Z
R47
RCY010004Z
R58
RCY011024Z
R313
RCY011024Z
R314
RCY011024Z
R320
RCY011024Z
Capacitors
Ref#
Description
MFR. Part No.
C1
E/C 1000UF 25WV Z
CE0251087Z
C2
CHIP/C (SMD) 0.1UF 25WV Z Y5V
CK2104AB7R
C3
CHIP/C (SMD) 1UF 16WV Z Y5V
CK5105AB7R
C4
CK2104AB7R
C5
CK2104AB7R
C6
CHIP/C (SMD) 0.01UF 50WV K X7R
CK1103AB5X
C7
CK2104AB7R
C8
CK1103AB5X
C9
CK2104AB7R
C10
CK2104AB7R
C11
CHIP/C (SMD)4.7UF 1 6WV Z Y5V
CK5475AA7R
C12
CK2104AB7R
C13
CK2104AB7R
C14
CK1103AB5X
C15
CK5105AB7R
C16
CK5105AB7R
C17
CK2104AB7R
C18
E/C 100UF 16WV Z
CE0161077Z
C19
CK2104AB7R
C20
E/C 100UF 16WV Z
CE0161077Z
C21
CHIP/C (SMD) 0.001UF 50WV Z SL K X7R
CK1102AB7L
C22
CHIP/C (SMD) 15PF 50WV J CH
CK1150AB4A
C23
CHIP/C (SMD) 33PF 50WV J CH
CK1330AB4A
C24
CK5105AB7R
C25
CK2104AB7R
C26
CK1103AB5X
C27
CK1103AB5X
C28
CK2104AB7R
C29
CK2104AB7R
Ref#
Description
MFR. Part No.
VC1
TRIMMER/C(SMD)20PF TCZ03P200A110B00
CV038200AY
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C. 80PIN LC7232N-8985
YNRG0GX3SP
IC2
IC (SMD) TC4093BFN 14PIN
YNTA04093B
IC3
IC (SMD) BA6250F-TP 16PIN
YNRO06250F
IC4
YNRO06250F
IC5
YNRO06250F
IC6
IC (SMD) TK11650U 3PIN����
YNTO11650U
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) RN1403-TE85L
TYZRN1403Z
Q2
TYZRN1403Z
Q3
TYZRN1403Z
Q4
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q5
TY2SC2712G
Q6
T/R (SMD) RN2403-TE85L
TYZRN2403Z
Q7
TY2SC2712G
Q8
TY2SC2712G
Q9
T/R (SMD) 2SC2714-TE85L
TY2SC2714Z
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1SS355
EDSS00355Y
D2
DIODE (SMD) 1SS355
EDSS00355Y
D3
DIODE (SMD) 1SS355
EDSS00355Y
D4
DIODE (SMD) 1SS355
EDSS00355Y
D5
DIODE (SMD) 1SS355
EDSS00355Y
D6
DIODE (SMD) 1SS355
EDSS00355Y
D7
DIODE (SMD) 1SS355
EDSS00355Y
D8
DIODE (SMD) 1SS355
EDSS00355Y
D9
DIODE (SMD) 1SS355
EDSS00355Y
D10
DIODE (SMD) 1SS355
EDSS00355Y
D11
DIODE (SMD) 1SS355
EDSS00355Y
D12
DIODE (SMD) 1SS355
EDSS00355Y
D13
DIODE (SMD) 1SS355
EDSS00355Y
D14
DIODE (SMD) 1SS184-TE85L
EDSS00184Y
D15
EDSS00184Y
D16
EDSS00184Y
D17
EDSS00184Y
D18
DIODE (SMD) 1SS355
EDSS00355Y
D19
DIODE (SMD) 1SS355
EDSS00355Y
D20
DIODE (SMD) 1SS355
EDSS00355Y
D21
DIODE (SMD) 1SS355
EDSS00355Y
D22
DIODE (SMD) 1SS355
EDSS00355Y
D23
DIODE (SMD) 1SS355
EDSS00355Y
D24
DIODE (SMD) 1SS355
EDSS00355Y
D25
DIODE (SMD) 1SS181-TE85L
EDSS00181Y
D26
EDSS00181Y
D27
EDSS00181Y
D28
EDSS00181Y
D29
DIODE (SMD) 1SS355
EDSS00355Y
D30
DIODE (SMD) 1SS355
EDSS00355Y
D321
DIODE (SMD) 1SS355
EDSS00355Y
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL(SMD)� �NL453232T-102J
YCTLI1083F
Crystals
Ref#
Description
MFR. Part No.
X1
CRYSTAL HC-49/U 4.500MHz
EYCAP04500
Switch
Ref#
Description
MFR. Part No.
ROTARY SW GPS-0501
EWRT32000S
Connectors
Ref#
Description
MFR. Part No.
J301
PCB CONNECTOR/S 10P PH=2
EX07N48209
J305
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J306
PCB CONNECTOR/S 4P PH=2MM
EX07N48490
J308
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J309
EX07N48223
Copyright © 2002 CBTricks.com
