Galaxy
DX Radios DX93T
Chassis and Miscellaneous Parts
Ref#
Description |
MFR.
Part No.
FRONT PANEL |
LED WINDOW |
PTDX55090A |
FRONT PANEL |
DISPLAY BAR DX-93T |
PTDX55040A |
HIGH SWR ALERT |
KNOB (A-1) |
PT3600101A |
KNOB C-1 |
PT3600120A |
VOL/SQ |
OUTER KNOB |
PT3600170A |
MIC/TB |
OUTER KNOB |
PT3600170A |
ECHO/TIME |
OUTER KNOB |
PT3600170A |
FINE/COARSE |
OUTER KNOB |
PT3600170A |
VOL/SQ |
INNER KNOB |
PT3600180A |
MIC/TB |
INNER KNOB |
PT3600180A |
ECHO/TIME |
INNER KNOB |
PT3600180A |
FINE/COARSE |
INNER KNOB |
PT3600180A |
KNOB WASHER |
PT3600090A |
D SPRING A #6600 |
MT3600080T |
D SPRING B #7800 |
MT3600090T |
D SPRING D #8500 |
MT3600100T |
FRONT CHASSIS |
MTDX55060X |
PUSH SW(1) |
PUSH BOTTON |
MTDX91040N |
PUSH SW(1) |
PUSH KEY |
PT7001071C |
HANDLER |
MT3600030S |
ROTARY SW(1) |
SW CHASSIS |
MTDX55042X |
DC/S fixed plate |
MT3600180A |
ROTARY SW 24mm 5N |
EWRT32002S |
ROTARY SW 8N L=20MM |
EWRT32077S |
ID PLATE DX-93T |
BTDX91020A |
CLAMP |
GZZZ50000Z |
FOAM H15x30x11t |
XZZZ90021Z |
SOLDER PLATE 3.2mm |
XZZZ90002Z |
METER |
FOAM 14x14x2 |
XZZZ90053Z |
SET SCREW M2x0.4Px6 |
JS052006MN |
ECHO P.C.B |
SET SCREW T3x8-2 STEEL |
JS013008TH |
HEATSINK (2) |
JS013008TH |
Front panel (4) |
SET SCREW M3x0.5Px6 |
JS033006MN |
BLIND RIVET 3.2x6mm |
JF413206ZX |
CH(2) |
JS053006MN |
Chassis(12) |
JS053006MN |
ACER(1) |
JS053006MN |
CHASSIS(2) |
SET SCREW M3x0.5Px4 |
JS053004MN |
Main PCB(5) |
SET SCREW T3x6-2mm |
JS053006TN |
MAIN PCB(2) |
SET SCREW T3x4-2 |
JS053004TN |
SP |
NUT WITH WASHER M3x3.5t |
JN263035ZS |
10A(4) |
JS053006MN |
JS053006MN |
NUT WITH WASHER HM3x3.5t |
JN263035ZS |
SET SCREW W5x10-1 |
JS015010WH |
SET SCREW T3.5x8-2 |
JS013508TH |
OUT-TOOTH WASHER 5.5x10x0.3tmm |
JW315510CN |
IN-TOOTH WASHER 4x8x0.3tmm |
JW324008CN |
FIBER WASHER |
XZZZ90188Z |
SSSEB51H 905 271X 1219x0.8(SECC)0.15 |
HZZZ76005Z |
MIC JACK |
MIC JACK G4P |
EX06N41101 |
MIC JACK(1) |
SOLDER PLATE |
XZZZ90098Z |
ANT JACK |
EX06T41019 |
ANT JACK(1) |
SOLDER PLATE |
XZZZ90098Z |
TERMINAL CONNECTOR NP-1203 |
EX06N41036 |
DIODE LT6A400 |
EDLT6A400Z |
C/C 0.01UF 50WV SL Z |
CC0501037L |
L504 |
TUBE 1.2x15mm |
WX0012015A |
LEFT SIDE CHASSIS |
MTDX91020X |
RIGHT SIDE CHASSIS |
MTDX91030X |
BOTTOM HOUSING |
MT3600071X |
Bottom Housing(SP) |
SHIELD CLOTH 60x50x0.25t |
LZZZ60084Z |
Speaker(4) |
SET SCREW M3x0.5Px8 |
JS053008MN |
TOP HOUSING |
MT3600061X |
TR41 |
SET SCREW M2x0.4Px8 |
JS052008MN |
MICROPHONE ASSY,4P BLACK DMC507-012 |
EX04N40002 |
Galaxy |
MIC NAME PLATE GALAXY |
BT2100020A |
MIC STOPPER |
XZZZ90008Z |
MOUNTING SCREW BLACK |
XZZZ90007Z |
