Galaxy DX Radios DX93T
RF AMP PCB (EPAC05010B)
Trace Layout
Schematic Diagram
Schematic Diagram
Parts List
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/F/R (SMD) 47 OHM 0.1W
RCY014704Z
Later Production
CHIP/F/R (SMD) 10 OHM 0.1W
RCY011004Z
R2
RCY014704Z
Later Production
RCY011004Z
R3
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
Later Production
CHIP/F/R (SMD) 2.2K OHM 0.1W
RCY012224Z
R4
RCY011024Z
R5
RCY011024Z
R6
CHIP/F/R (S.M.D) 10K OHM 0.1W
RCY011034Z
R7
CHIP/F/R (SMD) 10 OHM 1/4W
RCY141004Z
R8
CHIP/F/R (SMD) 100 OHM 1/4W
RCY141014Z
R9
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
R10
RCY141004Z
R11
C/F/R P-TYPE 150 OHM 1/2W
RCP121514Z
Ref#
Description
MFR. Part No.
TH1
THERMISTOR (SMD) 2K OHM (TCM-A220E)
RTU142024Y
Capacitors
Ref#
Description
MFR. Part No.
C1
CHIP/C (SMD) 0.1UF 25WV Z Y5V
CK2104AB7R
C2
CK2104AB7R
C3
CHIP/C (SMD) 0.01UF 50WV K X7R
CK1103AB5X
C4
CK1103AB5X
C5
MICA CHIP/C 470PF 500WV J CH
CK3471BF4A
C6
CHIP/C (SMD) 330PF 100WV K CH
CK4331AA5A
C7
CK4331AA5A
C8
CHIP/C (SMD) 680PF 100WV K CH
CK4681AA5A
C9
CHIP/C (SMD) 0.01UF 100WV K X7R
CK4103AA5X
C10
CK4103AA5X
C11
CK4331AA5A
C12
CK1103AB5X
C13
CK1103AB5X
C14
CHIP/C(SMD) 0.001UF 50WV Z SLK X7R
CK1102AB7L
C15
CHIP/C (SMD) 0.1UF 100WV K X7R
CK4104AA5X
C16
CK1103AB5X
C17
CK1103AB5X
C18
RCY010004Z
C19
RCY010004Z
C20
CK2104AB7R
C21
CHIP/C (SMD) 560P 50WV K CH
CK1561AB5A
C22
CK4104AA5X
C23
C/C 0.1UF 50WV SL Z
CK4104AA5X
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1N4148
ED1N04148Y
D2
ZENER DIODE (SMD) 0.5W 8.2V RLZ
EDZD05829Y
Inductors
Ref#
Description
MFR. Part No.
L1
SPRING COIL 0.8x4.5x7t
ECSPG18002
L2
CHOKE COIL (SMD) NL322522T-220J
YCTLI2263C
Transistors
Ref#
Description
MFR. Part No.
Q1
TRANSISTOR (SMD) 2SB798DL-(T1)
TY2SB0798Z
Q2
T/R 2SC2290
T2SC02290Z
Q3
T/R 2SC2312C
T2SC02312C
Connectors
Ref#
Description
MFR. Part No.
J1
PCB CONNECTOR/S 2P
EX07N48152
J2
PCB CONNECTOR/S 2P
EX07N48152
GND(1)
C PIN HAC 220V
GZZZ50011Z
V+(1)
C PIN HAC 220V
GZZZ50011Z
Fan
Ref#
Description
MFR. Part No.
FAN (2)
DC FAN 12V DF124010SM
EX13N46008
DC FAN COVER FG-04
EX13N46009
SET SCREW M3x0.5Px16
JS013016MB
Hardware
Ref#
Description
MFR. Part No.
(Q3)2312C(1)
SET SCREW M3x0.5Px8
JS013008MN
PCB(2)
SET SCREW M3x0.5Px8
JS013008MN
(Q3)2312C
INSULATING PLATE 10x14x1.55mm
XZZZ90358Z
Copyright © 2002 CBTricks.com
