Galaxy
DX Radios DX949
Frequency
Conversion
1.
Remove bottom cover from radio. |
2.
On the main PCB, locate J33. (See diagram above) |
3.
Locate wires on pins marked "P5" (yellow) & "P6" (grey). |
4.
Cut wire on "P5" (yellow) and install a SPST switch in line. |
5.
Cut wire on "P6" (grey) and install a SPST switch in line. |
NOTE:
By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted. |
