Galaxy DX Radios DX949
Chassis & Mechanical
Ref. No.
Description
MFR. Part No.
CR
FRONT PANEL DX-949
PTDX55060A
KNOB WASHER
PT3600090A
CH
DISPLAY WINDOW
PTDX55020A
DX-949
LED BAR
PTDX55040A
Rotate SW
CH KNOB
PT148N021A
Dual VR(INNER)
INNER KNOB
PT148N100A
Single VR
VR KNOB
PT148N031A
Dual CR(OUTER)
PT148N090A
DX-949
MTDX55051X
HANDLER
MT3600030S
TOP HOUSING
MT3600061X
BOTTOM HOUSING
MT3600071X
Top & Bottom Housing
SHIELD CLOTH 10x170x0.3t
LZZZ60082Z
CLAMP 100MM
GZZZ50000Z
FOAM 11x30x15t
XZZZ90021Z
SOLDER PLATE
XZZZ90098Z
BLIND RIVET 3.2x6mm (AL)
JF413206ZX
Front panel (4)
SET SCREW M3x0.5Px6
JS033006MN
CH(2)� Chassis(14)
SET SCREW M3x0.5Px6
JS053006MN
Speaker(4)
SET SCREW M3x0.5Px8
JS053008MN
Main PCB(5)
SET SCREW T3x6-2
JS053006TN
Speaker(4)
NUT WITH WASHER M3x3.5t
JN263035ZS
STOPPER
UDT360003Z
MAIN UNIT BOARD
UDT360001Z
MIC STOPPER
XZZZ90008Z
MOUNTING SCREW M5x0.8Px11(BLACK)
XZZZ90007Z
SET SCREW W5x10-1
JS015010WH
SET SCREW T3.5x8-2
JS013508TH
OUT-TOOTH WASHER 5.5x10x0.3tmm
JW315510CN
IN-TOOTH WASHER 4x8x0.3tmm
JW324008CN
FIBER WASHER 4.9x15x1t
XZZZ90188Z
LEAD WIRE #26 (UL) 50MM RED 5:5
WL0205005Z
ANT SOCKET WITH TEETH WASHER
EX06T41019
DC SOCKET
DC SOCKET 3P
EX06T40007
DC SOCKET
DC SOCKET HOLDER
MT3600050X
DC SOCKET (2)
SET SCREW M3x0.5Px8
JS053008MN
  DC SOCKET
DIODE LT6A400
EDLT6A400Z
DC SOCKET (2)
C/C 0.01UF 50WV SL Z
CC0501037L
TP7-9
P.C.B. DC B+45.5x11.5x1.6
EPT120060A
SPEAKER
WIRE CONNECTOR/H 2P L=180MM
EX07N48041
J33
WIRE CONNECTOR/H 10P-10P L=100 PH=2
EX07N48967
J17-40ZJ2
WIRE CONNECTOR/H 2P-2P L=400mm
EX07N49030
J4
WIRE CONNECTOR/H 2P-2P L=250MM PH=2
EX07N48917
J14-20ZJ6-J5-40ZJ8
WIRE CONNECTOR/H 7P-4P-3P-2P L=100
EX07N49028
J6
WIRE CONNECTOR/H 3P-3P L=280MM PH=2
EX07N48920
J5
WIRE CONNECTOR/H 5P-5P L=120MM PH=2
EX07N48915
J30
WIRE CONNECTOR/H 2P-2P L=100MM PH=2
EX07N48918
J10
EX07N48918
J7
EX07N49031
J21
WIRE CONNECTOR/H 6P-4P-2P L=350/400
EX07N48887
J22
EX07N48887
JB-40ZJ6-J11
WIRE CONNECTOR/H 6P-3P-3P PH=2MM
EX07N48968
J20-METER
WIRE CONNECTOR/H 5P-4P L=80mm
EX07N48997
METERJ4-40ZJ16
WIRE CONNECTOR/H 2P-2P L=120mm
EX07N48901
METERJ1-40ZJ4
WIRE CONNECTOR/H 3P-3P L=100mm
EX07N49002
J11-20ZJ8-40ZJ12-J10
WIRE CONNECTOR/H 5P-3P-3P-2P-2P
EX07N49029
J18
WIRE CONNECTOR/H 3P-3P L=320 PH=2mm
EX07N49024
WIRE CONNECTOR/H 5P-5P L=400mm
EX07N49073
J9
WIRE CONNECTOR/H 3P-3P L=100 PH=2
EX07N49023
METERJ3-20ZJ9
WIRE CONNECTOR/H 2P-2P L=160mm
EX07N49005
LAMP-20J1
WIRE CONNECTOR/H 2P
EX07N48233
R233-50ZJ1
WIRE CONNECTOR/H 2P L=370mm PH=2mm
EX07N48896
Copyright © 1998,1999,2000,2002 CBTricks.com
