Galaxy DX Radios DX94HP
RF AMP PCB (EPAC10010A)
PCB Layout
Trace Layout
Schematic Diagram
Ref#
Description
MFR. Part No.
RF AMP P.C.B. EPAC10010B
Complete with Components.
#T-149D-D05
RF AMP P.C.B. 121x59x1.6tmm(d)
EPAC10010B
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/F/R (SMD) 10K OHM 1/2W
RCY051034Z
R2
CHIP/F/R (SMD) 56 OHM 0.1W
RCY015604Z
R3
RCY015604Z
R4
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R5
RCY011034Z
R6
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R8
RCY011034Z
R10
CHIP/F/R (SMD) 1K OHM 1/2W
RCY051024Z
R11
RCY011034Z
R12
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R13
RCY051034Z
R15
CHIP/F/R (SMD) 2.2K OHM 0.1W
RCY012224Z
R16
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R17
RCY011034Z
R18
CHIP/F/R (SMD) 10 OHM 0.1W
RCY011004Z
R19
RCY011004Z
R20
CHIP/F/R (SMD) 470 OHM 1/4W
RCY144714Z
R22
CHIP/F/R (SMD) 1K OHM 1/4W
RCY141024Z
R23
RCY141024Z
R24
CHIP/F/R (SMD) 47K OHM 1/4W
RCY144734Z
R25
RCY144734Z
R26
RCY012224Z
R29(30A)
M/O/R 100 OHM 2W
RFP201014Z
R30(30A)
M/O/R 100 OHM 2W
RFP201014Z
R31
RCY011024Z
R32
RCY011024Z
R33
RCY011034Z
VR1
S/F/R (SMD) 5 K (TMC3K)
RE502Y0129
VR2
RE502Y0129
Capacitors
Ref#
Description
MFR. Part No.
C1
CHIP/C 0.01UF 500WV K X7R
CK3103AA5X
C4
CHIP/C 0.01UF 50WV K X7R
CK1103AB5X
C5
CK1103AB5X
C6
CHIP/C 82PF 500WV J CH
CK3820AA4A
C7
CHIP/C 39PF 500WV J CH
CK3390AA4A
C8
CHIP/C 150PF 500WV J CH
CK3151AA4A
C9
CHIP/C 12PF 500WV J CH
CK3120AA4A
C10
CK3820AA4A
C11
CK3103AA5X
C13
CHIP/C 2.2UF 16WV Z Y5V
CK5225AA7R
C14
CHIP/C 0.1UF 50WV K X7R
CK1104AB5X
C15
CK1104AB5X
C16
CK1104AB5X
C18
CK5225AA7R
C19
CK1104AA5X
C20
CHIP/C 680PF 500WV J CH
CK3681AA4A
C21
CK1103AA5X
C22
CK1103AA5X
C26
CK1104AA5X
C27
CK1104AA5X
C28
E/C 470UF 25WV Z
CE0254777Z
C29
CK3820AA4A
C30
CK1104AB5X
C31
CK1104AB5X
C32
CK1104AB5X
C33
CK1104AA5X
C34
CK1104AA5X
C35
CK1104AA5X
C36
CK1104AA5X
C37
CK1104AA5X
C38
CK1104AA5X
C39
CK1104AA5X
C40
CK1104AA5X
C41
CK1104AA5X
C42
CK1104AA5X
C43
CK1103AB5X
C44
CK1103AB5X
C45
CK1104AB5X
C46
CK1104AB5X
C47
CK1104AB5X
C48
CK1104AB5X
C50
CK1104AA5X
C52(30A)
CK1103AA5X
C53(30A)
CK1103AA5X
C55
E/C 10UF 50WV Z
CE0501067Z
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q2
TY2SC2712G
Q3
TY2SC2712G
Q4
T/R (SMD) 2SB798DL-(T1)
TY2SB0798Z
Q5
TY2SC2712G
Q5
T/R IRF520
TIRF00520Z
INSULATING RING
XZZZ90003Z
INSULATING PLATE 10x14x1.55mm
XZZZ90358Z
SET SCREW M2x0.4Px10 4
JS052010MN
Q6
T/R IRF520
TIRF00520Z
INSULATING RING
XZZZ90003Z
XZZZ90358Z
JS052010MN
Q7
T/R IRF520
TIRF00520Z
INSULATING RING
XZZZ90003Z
XZZZ90358Z
JS052010MN
Q8
T/R IRF520
TIRF00520Z
INSULATING RING
XZZZ90003Z
XZZZ90358Z
JS052010MN
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) MA728-(TX)
EDMA00728Y
D2
DIODE (SMD) 1SS355
EDSS00355Y
D3
DIODE (SMD) 1N4148
ED1N04148Y
D5
DIODE (SMD) 1N4148
ED1N04148Y
D6
ZENER DIODE (SMD) 0.5W 8.2V (RLZ)
EDZD05829Y
D7
ZENER DIODE (SMD) RLZ5.6V
EDZD05569Y
D8
DIODE LT6A400
EDLT6A400Z
D9
LED (SMD) KP-3216ID (RED)
EX01Y40141
D10
DIODE (SMD) 1SS355
EDSS00355Y
Thermistor
Ref#
Description
MFR. Part No.
TH1
THERMISTOR (SMD) NSM2202J410J3R
RTU142024Y
Inductors
Ref#
Description
MFR. Part No.
L1
SPRING COIL 1.0x6x5T (SMD)
YCSPG18423
L2
YCSPG18423
L5
BEAD FERRITE COIL WB-403025
YCBAD18581
L7
YCBAD18581
Transformers
Ref#
Description
MFR. Part No.
T1
RF COIL ASS'Y #ST-182E-2 (3t)
ECRFZ10184
T2
RF COIL ASS'Y #ST-182E-3 (3t)
ECRFZ10185
Relay
Ref#
Description
MFR. Part No.
RL1
RELAY S2EB-12V(AG302360)
EX05N40844
Connectors
Ref#
Description
MFR. Part No.
J1(O/P)
A TYPE JACK (R PIN) TMP-J01X-A2
GZZZ50063Z
J2(I/P)
GZZZ50063Z
J5
PCB CONNECTOR/S 2P PH=2.5
EX07N41226
J7
EX07N41226
J3
PCB CONNECTOR/S 4P PH=2MM
EX07N48490
DC FAN
PCB CONNECTOR/S 2PIN PH=2.5
EX07N49289
Hardware
Ref#
Description
MFR. Part No.
ONSERT M2.6xxM5x3T
MTTURB160X
SET SCREW M2.6x0.45Px6
JS052606MN
PCB(x3)
SET SCREW M3x0.5Px6
JS053006MN
Copyright © 2007 CBTricks.com
