Galaxy DX Radios DX94HP
Transmitter Alignment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
Remove TP7-TP9 Jumper PCB.
TX CARRIER OSCILLATORS:
AM TX Mode
Band E CH. 1
Connect Frequency Counter to TP6
L25
LSB/TX mode: Adjust for 10.6975MHz 20Hz.
L24
USB/TX mode: Adjust for 10.6925MHz 20 Hz.
Connect Frequency Counter to TP5
L23
AM/TX mode: Adjust for 10.6950MHz 20 Hz.
DRIVER BIAS: (IRF520 Vg)
Set Radio to:
Band E, Ch.1
Mode to USB
MIKE GAIN at minimum.
Connect DC Ammeter between TP7 and TP9.
VR12
Key TX adjust for 100mA.
Verify 3.80vdc max.on bare lead of resistor in L37.
FINAL BIAS:  (IRF520 Vg)
Set Radio to:
Band E, Ch.1
Mode to USB
Connect DC Ammeter between TP7 and TP8.
****Warning****
Setting these adjustments are critical and exceeding the maximin voltage and current settings will cause damage to the transmitter and void the warranty.
VR10
Preset both VR10 & VR11 for zero mA in TX mode.
Key TX & adjust for 100mA.
Verify 3.65vdc max on bare lead of resistor in L34.
Replace TP7-TP9 Jumper PCB.
RF AMP CHAIN:
Set mode to AM.
Set RF power control fully clockwise.
Connect wattmeter to ANT output.
L44, L43,
L42, L40,
L44
Key TX & adjust (in order) for maximum RF output . Recheck power across entire freq range.
Re-adjust L44 for minimum SSB distortion.
SSB CARRIER BALANCE:
Set mode to USB
MIKE GAIN to minimum.
VR6
Key TX, adjust for min. carrier leakthrough on scope or wattmeter. Recheck on LSB mode. If necessary readjust for best balance of sideband suppression between LSB & USB
SSB APC:
Set mode to USB
Set RF power fully clockwise.
Connect DC voltmeter from pcb ground to TP7
VR17
In TX, adjust for 12.5vdc
SSB ALC:
Mode to USB.
MIKE GAIN to maximum.
Inject two-tone audio signal of 700Hz and 1900Hz, 30 mV to Mic input.
VR13
L44
In TX, adjust for
100 watts PEP.
Adjust for minimum distortion on scope
AM CARRIER POWER:
Set mode to AM,
RF Power SW to HI.
CAUTION! Do not exceed power levels. Damage to power transistors and inability to achieve 100% modulation from insufficient audio power will result.
 VR14
Set RF PWR fully clockwise
adjust VR14 for 35 watts
VR18
Set RF PWR fully counter clockwise.
Adjust for 5 watts
RF METER:
Set mode to AM,
RF Power fully clockwise
Meter Switch to PWR
VR9
Adjust so meter agrees with Wattmeter.
AMC:
Mode to AM.
Inject audio signal of 1KHz at 30mV to Mic input.
Connect modulation meter to ANT output.
VR16
Adjust for 100% modulation depth.
RF Amp PCB (EPAC10010B) Adjustment
Gate Voltage Adjust:
Set MIC GAIN to minimum.
SSB mode (either LSB/USB).
Connect DC voltmeter from Amp PCB ground to gate of Q5.
Key radio.
VR2
4.00VDC
SWR Meter Adjust:
Mode to AM.
Unkey radio PWR/SWR/RB switch to SWR.
Key radio.
Connect wattmeter / 50-ohm resistive dummy load to ANT output.
Remove 50-ohm dummy load and connect 100-ohm 100 watt load to radio antenna output connector.
PWR Control
VR1
Adjust to max (35 watts).
Adjust for 2:1 reading on radio SWR scale.
NOTE: If a 100-ohm 100 watt load is not available just use 50-ohm dummy load and set VR1 for 1:1 on SWR scale.
Copyright © 2007 CBTricks.com
