Galaxy DX Radios DX94HP
VR PCB (EPT99HP40A)
Trace Layout
Parts List
Ref#
Description
MFR. Part No.
VR PCB (DX-98VHP) EPT99HP40A
#T-149E-P09
EPT99HP40A
EPT99HP40A
Resistors
Ref#
Description
MFR. Part No.
R401
CHIP/F/R (SMD) 47 OHM 0.1W
RCY014704Z
R402
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R403
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R404
CHIP/F/R (SMD) 220K OHM 0.1W
RCY012244Z
R405
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R406
CHIP/F/R (SMD) 470K OHM 0.1W
RCY014744Z
R407
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R408
CHIP/F/R (SMD) 39K OHM 0.1W
RCY013934Z
R409
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
Capacitors
Ref#
Description
MFR. Part No.
C401
CHIP/C 4.7UF 16WV� Z� Y5V
CK5475AA7R
C402
CK5475AA7R
C403
CHIP/C 2.2UF 16WV Z Y5V
CK5225AB7R
C404
CK5225AB7R
Diodes
Ref#
Description
MFR. Part No.
D401
DIODE (SMD) 1SS355
EDSS00355Y
D402
DIODE (SMD) 1SS355
EDSS00355Y
Potentiometers
Ref#
Description
MFR. Part No.
(VOL/SQ)VR401
VR (RK097221101K) 50KB/50KA W/SW
RV50303522
(MIC/RF)VR402
VR (RK097221002E) 1KB/1KA
RV10203524
(DIM/POWER)VR403
VR 5KB/5KB W/SW
RV50203538
(ECHO/TIME)VR404
V/R L=30 50KA/50KA
RV50303620
(FINE/COARSE)VR405
VR 20KB/1KB
RV20303556
VR406
S/F/R (SMD) 2K (TMC3K)
RE202Y0186
Transistors
Ref#
Description
MFR. Part No.
Q401
T/R� (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q402
TY2SC2712G
Q403
TY2SC2712G
Connectors
Ref#
Description
MFR. Part No.
J401
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J402
PCB CONNECTOR/S 5P PH=2MM (WHITE)
EX07W48826
J403
EX07N48223
J404
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J405
EX07N48223
J406
PCB CONNECTOR/S 3P PH=2MM (WHITE)
EX07W48824
J407
EX07N48350
J408
EX07N48350
J409
EX07N48223
J410
EX07N48222
J411
EX07N48222
J412
EX07N48223
J413
PCB CONNECTOR/S 6P PH=2
EX07N48331
J416
EX07N48350
J415
EX07W48824
J417
EX07W48824
J418
EX07N48223
J419
EX07N48223
Copyright © 2007 CBTricks.com
