Galaxy DX Radios DX959
Clarifier Mod Method 1
Also SEE:
Method #2
Method 1:
1.
First, remove power to the radio. Remove the bottom chassis cover of the radio.
2.
Remove R113 and D68 as shown above.
3.
Connect a jumper wire between +8V and J9 pin F1.
4.
Perform an PLL alignment as shown below.
AM Frequency:
Set radio to CH 1 AM RX mode.
Clarifier control to center detent.
Connect frequency counter to TP3.
L20
16.27000 MHz � 20 Hz
USB Freq:
Set radio to CH 1 USB mode.
L21
16.27250 MHz � 20 Hz
LSB Freq:
Set radio to CH 1 LSB mode.
L22
16.26750 MHz � 20 Hz
Copyright © 1998,1999,2000, 2001, 2002, 2003CBTricks.com
