Galaxy DX Radios DX959
Ref#
Description
MFR. Part No.
CR
FRONT PANEL DX-959
PTDX55071A
KNOB WASHER
PT3600090A
Counter
ACRY WINDOW ORANGE
PT2100030B
CH
DISPLAY WINDOW
PTDX55020A
CH KNOB Rotate SW
PT148N021A
INNER KNOB Dual CR(INNER)
PT148N100A
VR KNOB Single VR
PT148N031A
OUTER KNOB Dual CR(OUTER)
PT148N090A
FRONT CHASSIS
MTDX55034X
HANDLER
MT3600030S
TOP HOUSING
MT3600061X
BOTTOM HOUSING
MT3600071X
Galaxy
MIC NAME PLATE
BA0112010A
Ref#
Description
MFR. Part No.
Top & Bottom Housing
SHIELD CLOTH 10x170x0.3t
LZZZ60082Z
CLAMP 100MM
GZZZ50000Z
Ref#
Description
MFR. Part No.
FOAM 11x30x15t
XZZZ90021Z
STOPPER
UDT360003Z
MAIN UNIT BOARD
UDT360001Z
MIC STOPPER
XZZZ90008Z
Ref#
Description
MFR. Part No.
DC
DC SOCKET 3P
EX06T40007
DC
DC SOCKET HOLDER
MT3600050X
DC(2)
SET SCREW M3x0.5Px8
JS053008MN
DC
DIODE LT6A400
EDLT6A400Z
DC(2)
C/C 0.01UF 50WV SL Z
CC0501037L
Ref#
Description
MFR. Part No.
ANT SOCKET WITH TEETH WASHER
EX06T41019
M/C PCB ANT SOCKET
SOLDER PLATE
XZZZ90098Z
Ref#
Description
MFR. Part No.
Front panel (4)
SET SCREW M3x0.5Px6
JS033006MN
3.2x6mm
BLIND RIVET
JF413206ZX
Speaker(4)
SET SCREW M3x0.5Px8
JS053008MN
Main PCB(5)
SET SCREW T3x6-2
JS053006TN
SET SCREW M2x0.4Px12
JS052012MN
SET SCREW M3x0.5Px6
JS013006MV
SET SCREW M2x0.4Px10
JS052010MN
SET SCREW W5x10-1
JS015010WH
SET SCREW T3.5x8-2
JS013508TH
MOUNTING SCREW M5x0.8Px11 (BLACK)
XZZZ90007Z
Ref#
Description
MFR. Part No.
OUT-TOOTH WASHER 5.5x10x0.3tmm
JW315510CN
IN-TOOTH WASHER 4x8x0.3tmm
JW324008CN
FIBER WASHER 4.9x15x1t
XZZZ90188Z
SP
NUT WITH WASHER M3x3.5t
JN263035ZS
Ref#
Description
MFR. Part No.
TP7-9
P.C.B. DC B+45.5x11.5x1.6
EPT120060A
WIRE CONNECTOR/H 2P L=180MM
EX07N48041
J33-J8
WIRE CONNECTOR/H 10P-10P L=100 PH=2
EX07N48967
J17-40ZJ2
WIRE CONNECTOR/H 2P-2P L=400mm
EX07N49030
J4-40ZJ1
WIRE CONNECTOR/H 2P-2P L=250MM PH=2
EX07N48917
J22-CN1
WIRE CONNECTOR/H 2P-2P L=160 PH=2
EX07N48921
J6-40Z
WIRE CONNECTOR/H 3P-3P L=280mm PH=2
EX07N49072
J5-40ZJ13
WIRE CONNECTOR/H 5P-5P L=120MM PH=2
EX07N48915
J21-CN2
WIRE CONNECTOR/H 7P-4P-2P-2P L=160
EX07N49034
J2
EX07N49034
J18
EX07N49034
J7-12
EX07N49031
J10
WIRE CONNECTOR/H 2P-2P L=100MM PH=2
EX07N48918
J13-J11
WIRE CONNECTOR/H 6P-3P-3P PH=2MM
EX07N48968
J6
EX07N48968
J20-METER
WIRE CONNECTOR/H 5P-4P L=80mm
EX07N48997
METERJ4-40ZJ16
WIRE CONNECTOR/H 2P-2P L=120mm
EX07N48901
J3-40ZJ15
WIRE CONNECTOR/H 5P-5P L=400mm PH=2
EX07N49027
METERJ1-40ZJ4
WIRE CONNECTOR/H 3P-3P L=100mm
EX07N49002
J11-J25-40ZJ12-20J,J10
WIRE CONNECTOR/H 5P-3P-3P-2P-2P
EX07N49029
J18-J9
WIRE CONNECTOR/H 3P-3P L=320 PH=2mm
EX07N49024
J9-J3
WIRE CONNECTOR/H 3P-3P L=100 PH=2
EX07N49023
J14-40ZJ7
WIRE CONNECTOR/H 7P-4P-3P L140
EX07N49033
J3
EX07N49033
SIGNAL METER-10J1
WIRE CONNECTOR/H 2P
EX07N48233
R223-50ZJ1
WIRE CONNECTOR/H 2P L=370mm PH=2mm
EX07N48896
Copyright © 1998,1999,2000,2002 CBTricks.com
