Galaxy
DX Radios DX95T
Channel Selector / Frequency
Counter PCB (EPT091V34Z)
Part Layout Top View
Trace Layout Top View
Part Layout Bottom View
Trace Layout Bottom View
Parts List
Ref#
Description |
MFR.
Part No.
ROTARY SW PCB EPT091V34Z (DX-95T) Complete with Components. |
#T-149B-P03 |
ROTARY SW PCB 98x140.15x1.6t(d) |
EPT091V34Z |
Resistors
Ref#
Description |
MFR.
Part No.
R1 |
CHIP/F/R (SMD) 0 OHM 0.1W |
RCY010004Z |
R3 |
RCY010004Z |
R5 |
CHIP/F/R (SMD)10K OHM 0.1W |
RCY011034Z |
R6 |
CHIP/F/R (SMD) 1K OHM 0.1W |
RCY011024Z |
R7 |
CHIP/F/R (SMD) 47K OHM 0.1W |
RCY014734Z |
R8 |
RCY014734Z |
R9 |
CHIP/F/R (SMD) 330 OHM 0.1W |
RCY013314Z |
R10 |
CHIP/F/R (SMD) 100 OHM 0.1W |
RCY011014Z |
R11 |
RCY011014Z |
R12 |
RCY011014Z |
R13 |
RCY011014Z |
R14 |
RCY011014Z |
R15 |
RCY011014Z |
R16 |
RCY011014Z |
R17 |
RCY011014Z |
R18 |
RCY011014Z |
R19 |
RCY011014Z |
R20 |
RCY011014Z |
R21 |
RCY011014Z |
R22 |
RCY011014Z |
R23 |
RCY011014Z |
R24 |
RCY011014Z |
R25 |
RCY011014Z |
R26 |
RCY011014Z |
R27 |
RCY011014Z |
R28 |
RCY011014Z |
R29 |
RCY011014Z |
R30 |
RCY011014Z |
R31 |
CHIP/F/R (SMD) 470 OHM 0.1W |
RCY014714Z |
R32 |
CHIP/F/R (SMD) 33K OHM 0.1W |
RCY013334Z |
R33 |
RCY011034Z |
R35 |
CHIP/F/R (SMD) 22K OHM 0.1W |
RCY012234Z |
R36 |
RCY012234Z |
R37 |
RCY012234Z |
R38 |
RCY012234Z |
R39 |
RCY012234Z |
R40 |
RCY012234Z |
R41 |
RCY011034Z |
R43 |
RCY011024Z |
R44 |
RCY014734Z |
R45 |
RCY014734Z |
R46 |
RCY012234Z |
R47 |
RCY010004Z |
R50 |
CHIP/F/R (SMD) 2.2K OHM 0.1W |
RCY012224Z |
R51 |
RCY012224Z |
Capacitors
Ref#
Description |
MFR.
Part No.
C1 |
E/C H=20mm 1000UF 25WV Z |
CE0251087Z |
C2 |
CHIP/C (SMD) 0.1UF 25WV Z Y5V |
CK2104AB7R |
C3 |
CHIP/C (SMD) 1UF 16WV Z Y5V |
CK5105AB7R |
C4 |
CK2104AB7R |
C5 |
CK2104AB7R |
C6 |
CHIP/C (SMD) 0.01UF 50WV K X7R |
CK1103AB5X |
C7 |
CK2104AB7R |
C8 |
CK1103AB5X |
C9 |
CK2104AB7R |
C10 |
CK2104AB7R |
C11 |
CHIP/C (SMD) 4.7UF 16WV� Z� Y5V |
CK5475AA7R |
C12 |
CK2104AB7R |
C13 |
CK2104AB7R |
C14 |
CK1103AB5X |
C15 |
CK5105AB7R |
C16 |
CK5105AB7R |
C17 |
CK2104AB7R |
C18 |
E/C 100UF 16WV Z |
CE0161077Z |
C19 |
CK2104AB7R |
C20 |
E/C 100UF 16WV Z |
CE0161077Z |
C21 |
CHIP/C (SMD) 0.001UF 50WV Z SL(K X7R) |
CK1102AB7L |
C22 |
CHIP/C (SMD) 15PF 50WV J CH |
CK1150AB4A |
C23 |
CHIP/C (SMD) 33PF 50WV J CH |
CK1330AB4A |
C24 |
CK5105AB7R |
C25 |
CK2104AB7R |
C26 |
CK1103AB5X |
C27 |
CK1103AB5X |
C28 |
CK2104AB7R |
C29 |
CK2104AB7R |
VC1 |
TRIMMER/C(SMD)20PF TCZ03P200A110B00 |
CV038200AY |
Integrated Circuits
Ref#
Description |
MFR.
Part No.
IC1 |
I.C. LC7232N-8985 80PIN |
YNRG0GX3SP |
IC2 |
IC (SMD) TC4093BFN 14PIN |
YNTA04093B |
IC3 |
IC (SMD) BA6250F-TP 16PIN |
YNRO06250F |
IC4 |
YNRO06250F |
IC5 |
YNRO06250F |
IC6 |
I.C.(MATSU)(SMD) AN8005M-E2 3PIN |
YNMA08005M |
Transistors
Ref#
Description |
MFR.
Part No.
Q1 |
T/R (SMD) RN1403 -TE85L |
TYZRN1403Z |
Q2 |
TYZRN1403Z |
Q3 |
TYZRN1403Z |
Q4 |
T/R (SMD) 2SC2712GR-TE85L |
TY2SC2712G |
Q5 |
TY2SC2712G |
Q6 |
T/R (SMD) RN2403 -TE85L |
TYZRN2403Z |
Q7 |
TY2SC2712G |
Q8 |
TY2SC2712G |
Q9 |
T/R (SMD) 2SC2714 -TE85L |
TY2SC2714Z |
Diodes
Ref#
Description |
MFR.
Part No.
D1 |
DIODE (SMD) 1SS355 |
EDSS00355Y |
D2 |
EDSS00355Y |
D3 |
EDSS00355Y |
D4 |
EDSS00355Y |
D5 |
EDSS00355Y |
D6 |
EDSS00355Y |
D7 |
EDSS00355Y |
D8 |
EDSS00355Y |
D9 |
EDSS00355Y |
D10 |
EDSS00355Y |
D11 |
EDSS00355Y |
D12 |
EDSS00355Y |
D13 |
EDSS00355Y |
D14 |
DIODE (SMD) 1SS184-TE85L |
EDSS00184Y |
D15 |
EDSS00184Y |
D16 |
EDSS00184Y |
D17 |
EDSS00184Y |
D18 |
EDSS00355Y |
D19 |
EDSS00355Y |
D20 |
EDSS00355Y |
D21 |
EDSS00355Y |
D22 |
EDSS00355Y |
D23 |
EDSS00355Y |
D24 |
EDSS00355Y |
D25 |
DIODE (SMD) 1SS181 -TE85L |
EDSS00181Y |
D26 |
EDSS00181Y |
D27 |
EDSS00181Y |
D28 |
EDSS00181Y |
D29 |
EDSS00355Y |
D30 |
EDSS00355Y |
Inductors
Ref#
Description |
MFR.
Part No.
L1 |
CHOKE COIL (SMD) NL453232T-102J |
YCTLI1083F |
Crystals
Ref#
Description |
MFR.
Part No.
X1 |
CRYSTAL HC-49/U 4.500MHz |
EYCAP04500 |
Switch
Ref#
Description |
MFR.
Part No.
ROTARY SW GPS-0501 |
EWRT32000S |
Connectors
Ref#
Description |
MFR.
Part No.
J301 |
PCB CONNECTOR/S 10P PH=2 |
EX07N48209 |
J305 |
PCB CONNECTOR/S 2P PH=2MM |
EX07N48223 |
J306 |
PCB CONNECTOR/S 4P PH=2MM |
EX07N48490 |
J308 |
PCB CONNECTOR/S 3P PH=2MM |
EX07N48350 |
J309 |
EX07N48223 |
