Galaxy DX Radios DX95T
Main PCB (EPT690010C)
MECHANICAL / CHASSIS:
FRONT PANEL DX-93T
PTDX55083A
KNOB WASHER
PT3600090A
FRONT PANEL
LED WINDOW
PTDX55090A
FRONT PANEL
DISPLAY BAR DX-949
PTDX55040A
COUNT WINDOW (PINK)
PT2100031D
DISPLAY WINDOW (CH) RED
PTDX55020B
HIGH SWR ALERT
KNOB (A-1)
PT3600101A
KNOB C-1
PT3600120A
VOL/SQ
OUTER KNOB
PT3600170A
MIC/TB
OUTER KNOB
PT3600170A
ECHO/TIME
OUTER KNOB
PT3600170A
FINE/COARSE
OUTER KNOB
PT3600170A
VOL/SQ
INNER KNOB
PT3600180A
MIC/TB
INNER KNOB
PT3600180A
ECHO/TIME
INNER KNOB
PT3600180A
FINE/COARSE
INNER KNOB
PT3600180A
EL DIRVER PCB
SHIELD HOUSING(EL)
MT240N060X
FRONT CHASSIS
MTDX55060X
ROTARY SW (1)
SW CHASSIS
MTDX55042X
PUSH SW (1)
PUSH BOTTON
MTDX91040C
HANDLER
MT3600030S
TOP HOUSING
MT2950031A
D SPRING A #6600
MT3600080T
D SPRING B #7800
MT3600090T
D SPRING D #8500
MT3600100T
DC/S fixed plate
MT3600180A
ROTARY SW 24mm 5N
EWRT32002S
ROTARY SW 8N L=20MM
EWRT32077S
ID PLATE DX-95T(100W)
BTDX91021A
EL PLATE DX-93T/DX-95T
BTDX55140A
PCB CONNECTOR/S 3P PH=2.54 (BLACK)
EX07N49373
Bottom Housing (SP)
SHIELD CLOTH 60x50x0.25t
LZZZ60084Z
CLAMP GT-100M
GZZZ50000Z
(B120/B174)
ON SETER
MTDX55080N
SLIDE SW
MASK PLATE(SW)
XZZZ90296A
FOAM 15x30x11t
XZZZ90021Z
REAR HEATSINK (2)
SOLDER PLATE 3.2mm
XZZZ90002Z
METER PCB (1)
SOLDER PLATE 3.2mm
XZZZ90002Z
POWER PCB
SPONGE 15x11x15mm
XZZZ90406Z
METER
SPONGE 10x10x1tmm(d)
XZZZ90418Z
90002Z(2)
SET SCREW M2x0.4Px4
JS052004MN
Front panel (4)
SET SCREW M3x0.5Px6
JS033006MN
Chassis (12)
SET SCREW M3x0.5Px6
JS053006MN
42X(2)
SET SCREW M3x0.5Px6
JS053006MN
Main PCB (7)
SET SCREW T3x6-2mm
JS053006TN
MAIN PCB (2)
SET SCREW T3x4-2
JS053004TN
SLIDE SW (10)
SET SCREW M2.6x0.45Px4
JS052604MN
METER PCB (4)
SET SCREW M2.6x0.45Px5
JS052605MN
SSSEB51H K905 271X 1219x0.8(SECC)0.15 KGS
HZZZ76005Z
DC FAN 12V DF124010SM
EX13N46008
ANT JACK
EX06T41019
REAR HEATSINK
MTDX91010A
LEFT SIDE CHASSIS
MTDX91020X
RIGHT SIDE CHASSIS
MTDX91030X
HEATSINK(PA)
MT2970060A
HEATSINK COVER/TOP Galaxy PCS
MT2970081B
SHIELD COVER(PA)
MT2970090X
SP
BOTTOM COVER
MT2970071A
10A
SHIELD CLOTH 100x25x0.3t
LZZZ60085Z
COVER (PA) (2970090X x6)
SET SCREW M3x0.5Px6
JS053006MN
DC FAN(4)
SET SCREW M3x0.5Px16
JS013016MB
HEATSINK (4)
SET SCREW M5x0.75Px8
JS055008MB
ANT JACK (1)
SOLDER PLATE
XZZZ90098Z
Copyright � 2003 CBTricks.com
