Galaxy DX Radios DX95T
Main PCB (EPT690010C)
Connectors
Ref#
Bd Loc
Description
MFR. Part No.
J1
PCB CONNECTOR/S 9P PH=2
EX07N48543
J3
PCB CONNECTOR/S 5P PH=2MM
EX07N48222
J5
EX07N48222
J6
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J7x2
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J9
PCB CONNECTOR/S 6P PH=2
EX07N48331
J10
EX07N48223
J11
EX07N48350
J12
PCB CONNECTOR/S 3P T PH=2.5(WHITE)
EX07N41227
J13
EX07N48331
J14
PCB CONNECTOR/S 7P PH=2MM
EX07N48224
J16
PCB CONNECTOR/S 2P T PH=2.5(WHITE)
EX07N41330
J17
EX07N48223
J18
EX07N48350
J20
PCB CONNECTOR/S 5P PH=2MM (WHITE)
EX07W48826
J21
PCB CONNECTOR/S 4P PH=2MM
EX07N48490
J22
EX07N48223
J25
EX07N48223
J26
EX07N48223
TP2
PCB CONNECTOR/S 1PIN L=11.8
EX07N48612
TP3
EX07N48612
TP5
EX07N48612
TP6
EX07N48612
Q41
EX07N48223
PA
EAR JACK 3.5mm
EX06N41045
EXT SP
EAR JACK 3.5mm
EX06N41045
TP7
PCB STOPPER
XZZZ90006Z
TP8
PCB STOPPER
XZZZ90006Z
TP9
PCB STOPPER
XZZZ90006Z
Wire
Ref#
Description
MFR. Part No.
R198-R223
LEAD WIRE #26 70MM WHITE 15:15
WL0907009Z
R201-R223
LEAD WIRE #26 70MM BROWN 15:15
WL0107009Z
J16-SP
WIRE CONNECTOR/H 2P L=300MM PH=2.5
EX07N48120
92Z(J921)-METER
WIRE CONNECTOR/H 2P L=100mm PH=2mm
EX07N48233
92Z(J912)-120Z(MOD LED PCB)
WIRE CONNECTOR/H 2P L=180MM PH=2MM
EX07N48888
J22-30Z(J309)
WIRE CONNECTOR/H 2P-2P L=160mm PH=2
EX07N48921
41A(J403)-92Z(J902)
WIRE CONNECTOR/H 2P-2P L=145MM PH=2
EX07N48850
Q41-92Z(J910)
WIRE CONNECTOR/H 2P-2P L=400mm
EX07N49030
J17-92Z(J923)
EX07N49031
J25-30Z(J305)
WIRE CONNECTOR/H 2P-2P L=400 PH=2MM
EX07N49098
J10-SW(27K)
WIRE CONNECTOR/H 2P L=280mm PH=2mm
EX07N48993
J26-92Z(J909)
WIRE CONNECTOR/H 2P-2P L=250mm PH=2
EX07N48917
J7-92Z(J921)
EX07N48917
30Z(J308)-41A(J401)
WIRE CONNECTOR/H 3P-3P L=200 PH=2
EX07N49212
J11-41A(J404)
WIRE CONNECTOR/H 3P-3P L=100mm PH=2
EX07N48914
J18-SW
WIRE CONNECTOR/H 3P L=400mm PH=2mm
EX07N48988
J6-92Z(J911)
WIRE CONNECTOR/H 3P-3P L=180 PH=2
EX07N49209
J21-30Z(J306)
WIRE CONNECTOR/H 4P-4P L=160 PH=2MM
EX07N49101
J20-41A(J402)
WIRE CONNECTOR/H 5P-5P L=120 PH=2
EX07N49213
J5-92Z(J903)
EX07N49210
J13-92Z(J904)
WIRE CONNECTOR/H 6P-3P-3P L=120PH=2
EX07N49215
J13-92Z(J920)
EX07N49215
J9-92Z(J915)
EX07N49216
J9-92Z(J916)
EX07N49216
J3-92Z(J922)
WIRE CONNECTOR/H 5P-5P L=400 PH=2
EX07N49208
J14-SW
WIRE CONNECTOR/H 7P L=100MM PH=2MM
EX07N49087
J1-92Z(J914)-SW
WIRE CONNECTOR/H 9P-2P L=120 PH=2
EX07N49211
30Z(J301)-MAIN PCB
WIRE CONNECTOR/H 10P L=120mm PH=2mm
EX07N48910
POWER PCB
WIRE CONNECTOR/H #18 6P L=230/210mm
EX07N49288
POWER PCB(J5)-MAIN PCB(B+/B-)
WIRE CONNECTOR/H 2P PH=2.5 L=250
EX07N49262
POWER
BEAD COIL
ECBAD18573
11D(J2)-MAIN PCB
WIRE CONNECTOR/H 4P L=280mm PH=2mm
EX07N49305
11D(J1)-MAIN PCB
WIRE CONNECTOR/H 2P L=350MM PH=2.5
EX07N48212
POWER PCB(I/P)-MAIN PCB
CABLE RG-316U 250mm SINGLE SIDE
WX0412925A
POWER PCB(O/P)-ANT JACK
WX0412925A
Jumper Wire
Ref#
Bd Loc
Description
MFR. Part No.
JP1
JUMPER WIRE 6x5x6mm
WX01060605
JP2
JUMPER WIRE 6x5x6mm
WX01060605
JP3
JUMPER WIRE 6x5x6mm
WX01060605
JP4
JUMPER WIRE 6x5x6mm
WX01060605
JP6
JUMPER WIRE 6x10x6mm
WX01060610
JP7
JUMPER WIRE 6x5x6mm
WX01060605
JP8
JUMPER WIRE 6x5x6mm
WX01060605
JP9
JUMPER WIRE 6x5x6mm
WX01060605
JP10
WX01060610
JP11
WX01060610
JP12
WX01060610
JP16
WX01060610
JP17
WX01060610
JP18
WX01060610
JP19
WX01060610
JP23
JUMPER WIRE 6x5x6mm
WX01060605
JP24
JUMPER WIRE 6x5x6mm
WX01060605
JP25
JUMPER WIRE 6x5x6mm
WX01060605
JP26
JUMPER WIRE 6x5x6mm
WX01060605
JP32
JUMPER WIRE 6x5x6mm
WX01060605
JP33
JUMPER WIRE 6x5x6mm
WX01060605
JP34
WX01060610
JP35
WX01060610
JP36
WX01060610
JP37
WX01060610
JP38
JUMPER WIRE 6x5x6mm
WX01060605
JP39
JUMPER WIRE 6x5x6mm
WX01060605
JP40
WX01060610
JP41
WX01060610
JP42
WX01060610
JP43
WX01060610
JP44
WX01060610
JP45
WX01060610
JP46
WX01060610
JP47
WX01060610
JP48
WX01060610
JP49
WX01060610
JP50
JUMPER WIRE 6x5x6mm
WX01060605
JP51
WX01060610
JP52
WX01060610
JP53
WX01060610
JP54
JUMPER WIRE 6x5x6mm
WX01060605
JP55
JUMPER WIRE 6x5x6mm
WX01060605
JP56
JUMPER WIRE 6x5x6mm
WX01060605
JP57
JUMPER WIRE 6x5x6mm
WX01060605
JP58
WX01060610
JP59
JUMPER WIRE 6x5x6mm
WX01060605
JP60
WX01060610
JP61
JUMPER WIRE 6x5x6mm
WX01060605
JP62
JUMPER WIRE 6x5x6mm
WX01060605
JP64
WX01060610
JP65
JUMPER WIRE 6x5x6mm
WX01060605
JP66
JUMPER WIRE 6x5x6mm
WX01060605
JP67
WX01060610
JP70
WX01060610
JP71
JUMPER WIRE 6x5x6mm
WX01060605
JP72
JUMPER WIRE 6x5x6mm
WX01060605
JP75
JUMPER WIRE 7x12x7mm
WX01070712
JP76
WX01070712
JP77
WX01070712
JP78
WX01070712
JP79
JUMPER WIRE 6x5x6mm
WX01060605
JP80
JUMPER WIRE 6x5x6mm
WX01060605
JP81
WX01070712
JP82
JUMPER WIRE 6x5x6mm
WX01060605
JP85
JUMPER WIRE 6x5x6mm
WX01060605
JP86
JUMPER WIRE 6x5x6mm
WX01060605
JP87
JUMPER WIRE 6x5x6mm
WX01060605
JP88
WX01060610
JP90
JUMPER WIRE 6x5x6mm
WX01060605
JP91
JUMPER WIRE 6x5x6mm
WX01060605
JP93
JUMPER WIRE 6x5x6mm
WX01060605
JP94
WX01060610
JP95
WX01060610
JP96
WX01060610
JP99
JUMPER WIRE 7x13x7mm
WX01070713
JP100
JUMPER WIRE 6x5x6mm
WX01060605
JP101
WX01060610
JP103
WX01060610
JP104
WX01060610
JP105
JUMPER WIRE 6x5x6mm
WX01060605
JP106
JUMPER WIRE 6x5x6mm
WX01060605
JP107
WX01060610
JP108
WX01060610
JP109
WX01060610
JP110
WX01060610
JP111
WX01060610
JP115
JUMPER WIRE 6x5x6mm
WX01060605
JP116
WX01060610
JP117
WX01060610
JP118
JUMPER WIRE 6x5x6mm
WX01060605
JP119
JUMPER WIRE 6x5x6mm
WX01060605
JP120
JUMPER WIRE 6x5x6mm
WX01060605
JP121
JUMPER WIRE 6x5x6mm
WX01060605
JP122
JUMPER WIRE 6x5x6mm
WX01060605
JP124
JUMPER WIRE 6x5x6mm
WX01060605
JP125
JUMPER WIRE 6x5x6mm
WX01060605
JP126
JUMPER WIRE 6x5x6mm
WX01060605
JP127
WX01060610
JP128
JUMPER WIRE 6x5x6mm
WX01060605
JP129
WX01060610
JP130
WX01060610
JP131
WX01060610
JP132
WX01060610
JP133
WX01060610
JP135
JUMPER WIRE 6x5x6mm
WX01060605
JP136
WX01060610
JP137
WX01060610
JP138
JUMPER WIRE 6x5x6mm
WX01060605
JP139
JUMPER WIRE 6x5x6mm
WX01060605
JP140
JUMPER WIRE 6x5x6mm
WX01060605
JP141
JUMPER WIRE 6x5x6mm
WX01060605
JP142
JUMPER WIRE 6x5x6mm
WX01060605
JP143
WX01060610
JP144
JUMPER WIRE 6x5x6mm
WX01060605
JP147
WX01060610
JP148
WX01060610
JP149
JUMPER WIRE 6x5x6mm
WX01060605
JP150
WX01060610
JP151
WX01060610
JP152
JUMPER WIRE 6x5x6mm
WX01060605
JP153
JUMPER WIRE 6x5x6mm
WX01060605
JP154
JUMPER WIRE 6x5x6mm
WX01060605
JP155
JUMPER WIRE 6x5x6mm
WX01060605
JP156
JUMPER WIRE 6x5x6mm
WX01060605
JP157
JUMPER WIRE 6x5x6mm
WX01060605
JP158
WX01060610
JP159
JUMPER WIRE 6x5x6mm
WX01060605
JP160
JUMPER WIRE 6x5x6mm
WX01060605
JP161
WX01060610
JP162
WX01060610
JP163
JUMPER WIRE 6x5x6mm
WX01060605
JP164
JUMPER WIRE 6x5x6mm
WX01060605
JP165
JUMPER WIRE 6x5x6mm
WX01060605
JP166
JUMPER WIRE 6x5x6mm
WX01060605
JP167
WX01060610
JP168
JUMPER WIRE 6x5x6mm
WX01060605
JP169
WX01060610
JP170
JUMPER WIRE 6x5x6mm
WX01060605
JP171
JUMPER WIRE 6x5x6mm
WX01060605
JP172
JUMPER WIRE 6x5x6mm
WX01060605
JP173
JUMPER WIRE 6x5x6mm
WX01060605
JP174
JUMPER WIRE 6x5x6mm
WX01060605
JP175
JUMPER WIRE 6x5x6mm
WX01060605
JP176
JUMPER WIRE 6x5x6mm
WX01060605
JP176
WX01060610
JP177
JUMPER WIRE 6x5x6mm
WX01060605
JP177
JUMPER WIRE 6x5x6mm
WX01060605
JP178
JUMPER WIRE 6x5x6mm
WX01060605
JP179
JUMPER WIRE 6x5x6mm
WX01060605
JP181
JUMPER WIRE 6x5x6mm
WX01060605
JP182
JUMPER WIRE 6x5x6mm
WX01060605
JP184
JUMPER WIRE 6x5x6mm
WX01060605
JP188
JUMPER WIRE 6x5x6mm
WX01060605
JP190
JUMPER WIRE 6x5x6mm
WX01060605
JP193
WX01070712
JP195
WX01060610
JP196
WX01060610
JP197
WX01070712
JP198
WX01060610
JP200
JUMPER WIRE 7x5x7mm
WX01070705
JP201
JUMPER WIRE 7x5x7mm
WX01070705
JP202
JUMPER WIRE 7x5x7mm
WX01070705
JP204
JUMPER WIRE 7x5x7mm
WX01070705
JP205
JUMPER WIRE 7x5x7mm
WX01070705
JP209
JUMPER WIRE 7x5x7mm
WX01070705
JP210
JUMPER WIRE 7x5x7mm
WX01070705
JP211
JUMPER WIRE 7x5x7mm
WX01070705
JP214
JUMPER WIRE 7x5x7mm
WX01070705
JP215
JUMPER WIRE 7x10x7mm
WX01070710
JP217
JUMPER WIRE 7x5x7mm
WX01070705
JP218
WX01070710
JP219
JUMPER WIRE 7x5x7mm
WX01070705
JP220
JUMPER WIRE 7x5x7mm
WX01070705
JP222
WX01070710
JP223
WX01070710
JP224
JUMPER WIRE 7x5x7mm
WX01070705
JP225
WX01070710
JP226
JUMPER WIRE 7x5x7mm
WX01070705
JP227
WX01070710
JP228
WX01070710
JP229
WX01070710
JP230
WX01070710
JP231
JUMPER WIRE 7x5x7mm
WX01070705
JP232
JUMPER WIRE 7x5x7mm
WX01070705
JP233
JUMPER WIRE 7x5x7mm
WX01070705
JP234
WX01070710
JP235
JUMPER WIRE 7x5x7mm
WX01070705
JP236
JUMPER WIRE 7x5x7mm
WX01070705
JP238
JUMPER WIRE 7x5x7mm
WX01070705
JP239
JUMPER WIRE 7x5x7mm
WX01070705
JP240
WX01070710
JP241
WX01070710
JP242
JUMPER WIRE 7x5x7mm
WX01070705
JP243
JUMPER WIRE 7x5x7mm
WX01070705
JP244
WX01070710
JP245
JUMPER WIRE 7x5x7mm
WX01070705
JP246
WX01070710
JP247
WX01070710
JP248
WX01070710
JP249
WX01070710
JP250
JUMPER WIRE 7x5x7mm
WX01070705
JP251
WX01070710
JP252
JUMPER WIRE 7x5x7mm
WX01070705
JP253
JUMPER WIRE 7x5x7mm
WX01070705
JP254
WX01070710
JP255
JUMPER WIRE 7x5x7mm
WX01070705
JP256
JUMPER WIRE 7x5x7mm
WX01070705
JP257
JUMPER WIRE 7x5x7mm
WX01070705
JP258
JUMPER WIRE 7x5x7mm
WX01070705
JP259
JUMPER WIRE 7x5x7mm
WX01070705
JP260
JUMPER WIRE 7x5x7mm
WX01070705
JP261
WX01070710
JP262
JUMPER WIRE 7x5x7mm
WX01070705
JP263
JUMPER WIRE 7x5x7mm
WX01070705
JP265
JUMPER WIRE 7x5x7mm
WX01070705
JP266
WX01070710
JP267
JUMPER WIRE 7x5x7mm
WX01070705
JP271
JUMPER WIRE 7x5x7mm
WX01070705
JP272
JUMPER WIRE 7x5x7mm
WX01070705
JP274
WX01070710
JP275
WX01070710
JP276
JUMPER WIRE 7x5x7mm
WX01070705
JP277
WX01070710
JP278
JUMPER WIRE 7x5x7mm
WX01070705
JP279
JUMPER WIRE 7x5x7mm
WX01070705
JP280
JUMPER WIRE 7x5x7mm
WX01070705
JP285
JUMPER WIRE 7x5x7mm
WX01070705
JP286
WX01070710
JP287
WX01070710
JP289
WX01070710
JP290
WX01070710
JP291
JUMPER WIRE 7x5x7mm
WX01070705
J2
JUMPER WIRE 7x3x7mm
WX01070703
J28
JUMPER WIRE 7x3x7mm
WX01070703
Q45
JUMPER WIRE 7x3x7mm
WX01070703
R19
JUMPER WIRE 7x5x7mm
WX01070705
R119
JUMPER WIRE 7x5x7mm
WX01070705
R305
JUMPER WIRE 7x5x7mm
WX01070705
C193
JUMPER WIRE 7x5x7mm
WX01070705
L36
WX01070710
Copyright � 2003 CBTricks.com
