Galaxy DX Radios DX95T
RF AMP PCB (EPA010011D)
Trace Layouts
Copper Side Parts
Schematic
Ref#
Description
MFR. Part No.
RF AMP (SMD) EPA010011D(DX-93T) Complete with Components
#T-141Q-P12
RF AMP P.C.B. 121x58x1.6tmm (d)
EPA010011D
Resistors
Ref#
Description
MFR. Part No.
R14
CHIP/F/R (SMD) 270 OHM 1W
RCY102714Z
R15
CHIP/F/R (SMD) 10K OHM 1/2W
RCY051034Z
R16
CHIP/F/R (SMD) 100 OHM 1/4W
RCY141014Z
R18
CHIP/F/R (SMD) 10 OHM 1/4W
RCY141004Z
R19
RCY141004Z
R21
CHIP/F/R (SMD) 1K OHM 1/4W
RCY141024Z
R22
CHIP/F/R (SMD) 470 OHM 1/4W
RCY144714Z
R24
CHIP/F/R (SMD) 2.2K OHM 0.1W
RCY012224Z
R25
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R26
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R27
CHIP/F/R (SMD) 47 OHM 0.1W
RCY014704Z
R28
RCY014704Z
Capacitors
Ref#
Description
MFR. Part No.
C5
CHIP/C (SMD) 2PF 50WV C CH
CK1020AA1A
C6
CHIP/C (SMD) 1PF 50WV C CH
CK1010AA1A
C7
CHIP/C (SMD) 0.01UF 500WV K X7R
CK3103AA5X
C8
CK3103AA5X
C9
CHIP/C (SMD) 560PF 50WV K CH
CK1561AA5A
C10
CHIP/C (SMD) 0.1UF 50WV K X7R
CK1104AA5X
C12
T/C (SMD) 2.2 UF 16WV M ('A'CASE)
CTY162256Z
C13
CHIP/C (SMD) 220PF 50WV K CH
CK1221AA5A
C18
CHIP/C (SMD) 150PF 50WV K CH
CK1151AA5A
C19
CK1151AA5A
C23
CK1104AA5X
C24
CK1104AA5X
C25
CK1104AA5X
C26
CK1104AA5X
C27
CK1104AA5X
C28
CK1104AA5X
C29
CK1104AA5X
C30
E/C 470UF 25WV Z
CE0254777Z
C31
MICA CHIP/C 68PF 500WV J CH
CK3680BC4A
C32
MICA CHIP/C 39PF 500WV J CH
CK3390BC4A
C33
MICA CHIP/C 150PF 500WV K CH
CK3151BC4A
C34
MICA CHIP/C 12PF 500WV J CH
CK3120BC4A
C35
MICA CHIP/C 120PF 500WV J CH
CK3121BC4A
C37
CK1104AA5X
C38
CK1104AA5X
C39
CK1104AA5X
C40
CK1104AA5X
C41
CK1104AA5X
C42
CK1104AA5X
C43
CK1104AA5X
C44
CK1104AA5X
C45
CK1104AA5X
C47
CHIP/C (SMD) 0.1UF 25WV Z Y5V
CK2104AB7R
C48
CK2104AB7R
C49
CK2104AB7R
C50
CK2104AB7R
C51
CK2104AB7R
Q3
MICA/C 330PF 500V J
CD5003314Z
Q4
MICA/C 330PF 500V J
CD5003314Z
Q3
MICA/C 470PF 500WV J
CD5004714Z
R23
CHIP/C (SMD) 0.001UF 50WV K X7R
CK1102AB5X
Transistors
Ref#
Description
MFR. Part No.
Q2
T/R (SMD) DTC114EUAT106
TYDTC114EA
Q3
T/R 2SC2290
T2SC02290Z
Q3(2)
SET SCREW M3x0.5Px8
JS013008MN
Q4
T/R 2SC2290
T2SC02290Z
Q4(2)
SET SCREW M3x0.5Px8
JS013008MN
Q5
T/R 2SD2531
T2SD02531Z
Q5
SET SCREW M3x0.5Px6
JS053006MN
Q6
T/R SMD) 2SB798DL-(T1)
TY2SB0798Z
Diodes
Ref#
Description
MFR. Part No.
D6
DIODE (SMD) 1N4148
ED1N04148Y
D7
DIODE (SMD) 1N4148
ED1N04148Y
D8
DIODE (SMD) 1N4148
ED1N04148Y
D9
DIODE (SMD) 1N4148
ED1N04148Y
D10
DIODE LT6A400
EDLT6A400Z
D11
ZENER DIODE (SMD) 0.5W 8.2V (RLZ)
EDZD05829Y
Thermistor
Ref#
Description
MFR. Part No.
TH1
THERMISTOR (SMD) (2K) NSM2202J410J3Z
RTU142024Y
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL (SMD) 100UH TF J
YCTLI1073F
L2
(CME)BRAND CORE BF 2159576
ECRFZ10204
L3
BEAD FERRITE COIL WB-403025
YCBAD18581
L4
YCBAD18581
L5
YCBAD18581
L6
SPRING COIL (SMD) 1.0Fx6.8Fx6T
YCSPG18400
L7
YCSPG18400
Transformers
Ref#
Description
MFR. Part No.
T1
RF COIL ASS'Y #ST-182E-2 (3t)
ECRFZ10184
T2
RF COIL ASS'Y #ST-182E-3 (3t)
ECRFZ10185
Relay
Ref#
Description
MFR. Part No.
RL1
RELAY S2EB-12V(AG302360)
EX05N40844
Fan
Ref#
Description
MFR. Part No.
Fan
DC FAN G12V DF124010SM
EX13N46008
Connectors
Ref#
Description
MFR. Part No.
J1
PCB CONNECTOR/S 2P PH=2.5
EX07N41226
J2
PCB CONNECTOR/S 4P PH=2MM
EX07N48490
J5
EX07N41226
DC FAN
PCB CONNECTOR/S 2PIN PH=2.5
EX07N49289
I/P
A TYPE JACK(R PIN) TMP-J01X-A2
GZZZ50063Z
O/P
GZZZ50063Z
Hardware
Ref#
Description
MFR. Part No.
POWER
PCB(3)
SET SCREW M3x0.5Px6
JS053006MN
Copyright © 2002 CBTricks.com
