Galaxy DX Radios DX95T2
Channel Selector / Frequency Counter PCB (EPT091V30A)
Part Layout Top View
Trace Layout Top View
Part Layout Bottom View
Trace Layout Bottom View
Parts List
Ref#
Description
MFR. Part No.
ROTARY SW PCB EPT091V30A/95T2
#T-149C-P03
ROTARY SW PCB 98x140.15x1.6t(d)
EPT091V30A
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
R3
RCY010004Z
R5
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
R6
CHIP/F/R (SMD) 560 OHM 0.1W
RCY015614Z
R7
CHIP/F/R (SMD) 470 OHM 0.1W
RCY014714Z
R9
CHIP/F/R (SMD) 330 OHM 0.1W
RCY013314Z
R10
CHIP/F/R (SMD) 100 OHM 0.1W
RCY011014Z
R11
RCY011014Z
R12
RCY011014Z
R13
RCY011014Z
R14
RCY011014Z
R15
RCY011014Z
R16
RCY011014Z
R17
RCY011014Z
R18
RCY011014Z
R19
RCY011014Z
R20
RCY011014Z
R21
RCY011014Z
R22
RCY011014Z
R23
RCY011014Z
R24
RCY011014Z
R25
RCY011014Z
R26
RCY011014Z
R27
RCY011014Z
R28
RCY011014Z
R29
RCY011014Z
R30
RCY011014Z
R31
RCY011014Z
R32
CHIP/F/R (SMD) 1K OHM 0.1W
RCY011024Z
R33
RCY011034Z
R34
CHIP/F/R (SMD) 100K OHM 0.1W
RCY011044Z
R35
RCY011034Z
R36
RCY013314Z
R37
CHIP/F/R (SMD) 39K OHM 0.1W
RCY013934Z
R38
RCY011034Z
R39
RCY011034Z
R40
RCY011034Z
R43
RCY015614Z
R44
CHIP/F/R (SMD) 47K OHM 0.1W
RCY014734Z
R45
RCY014734Z
R46
CHIP/F/R (SMD) 22K OHM 0.1W
RCY012234Z
R47
CHIP/F/R (SMD) 4.7K OHM 0.1W
RCY014724Z
R50
RCY014724Z
R51
RCY014724Z
R52
RCY013314Z
R53
CHIP/F/R (SMD) 47 OHM 0.1W
RCY014704Z
R54
CHIP/F/R (SMD) 220 OHM 0.1W
RCY012214Z
R55
CHIP/F/R (SMD) 1M OHM 0.1W
RCY011054Z
R56
RCY011024Z
R57
RCY011034Z
R58
RCY011034Z
R59
RCY011034Z
Capacitors
Ref#
Description
MFR. Part No.
C1
E/C 100UF 16WV Z
CE0161077Z
C2
CHIP/C 0.01UF 50WV K X7R
CK1103AB5X
C3
CK1103AB5X
C4
CHIP/C 0.1UF 25WV Z Y5V
CK2104AB7R
C5
CK1103AB5X
C6
CK2104AB7R
C7
CK2104AB7R
C8
CK2104AB7R
C9
CK2104AB7R
C10
CK2104AB7R
C11
CHIP/C 4.7UF 16WV� Z� Y5V
CK5475AA7R
C12
CK2104AB7R
C13
CK1103AB5X
C14
CK1103AB5X
C15
CK2104AB7R
C16
CK2104AB7R
C17
CK2104AB7R
C18
E/C 100UF 16WV Z
CE0161077Z
C19
E/C 100UF 16WV Z
CE0161077Z
C20
E/C 100UF 16WV Z
CE0161077Z
C21
CK1103AB5X
C23
CHIP/C 15PF 50WV J CH
CK1150AB4A
C24
CHIP/C 1UF 16WV Z Y5V
CK5105AB7R
C25
CK2104AB7R
C26
CK1103AB5X
C27
CK1103AB5X
C28
CK2104AB7R
C29
CK2104AB7R
C30
CK1103AB5X
VC1
TRIMMER/C (S.M.D.) 20PF 3.8p (TAPING)
CV038200AY
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C. (RANGER) HT48R50A-48 (SMD) 48PIN
YNRGFC04SP
IC2
I.C. (PHILIPS) 74HC161D 16PIN (SMD)
YNPHHC161D
IC3
I.C. (JRC) NJM78L05UA-TE1 3P (SMD)
YNJR78L05Z
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) RN1403 -TE85L
TYZRN1403Z
Q2
TYZRN1403Z
Q3
TYZRN1403Z
Q4
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q5
TY2SC2712G
Q6
T/R (SMD) RN2403-TE85L
TYZRN2403Z
Q7
TY2SC2712G
Q8
TY2SC2712G
Q9
T/R (SMD) 2SC2714Y-TE85L (T5L)
TY2SC2714Z
Q10
T/R (SMD) 2SA1162GR-TE85L
TY2SA1162G
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1SS355
EDSS00355Y
D2
DIODE (SMD) 1SS355
EDSS00355Y
D3
DIODE (SMD) 1SS355
EDSS00355Y
D4
DIODE (SMD) 1SS355
EDSS00355Y
D5
DIODE (SMD) 1SS355
EDSS00355Y
D6
DIODE (SMD) 1SS355
EDSS00355Y
D7
DIODE (SMD) 1SS355
EDSS00355Y
D8
DIODE (SMD) 1SS355
EDSS00355Y
D9
DIODE (SMD) 1SS355
EDSS00355Y
D10
DIODE (SMD) 1SS355
EDSS00355Y
D11
DIODE (SMD) 1SS355
EDSS00355Y
D12
DIODE (SMD) 1SS355
EDSS00355Y
D13
DIODE (SMD) 1SS355
EDSS00355Y
D14
DIODE (SMD) 1SS184-TE85L
EDSS00184Y
D15
EDSS00184Y
D16
EDSS00184Y
D17
EDSS00184Y
D18
DIODE (SMD) 1SS355
EDSS00355Y
D19
DIODE (SMD) 1SS355
EDSS00355Y
D20
DIODE (SMD) 1SS355
EDSS00355Y
D21
DIODE (SMD) 1SS355
EDSS00355Y
D22
DIODE (SMD) 1SS355
EDSS00355Y
D23
DIODE (SMD) 1SS355
EDSS00355Y
D24
DIODE (SMD) 1SS355
EDSS00355Y
D25
DIODE (SMD) 1SS181 -TE85L
EDSS00181Y
D26
EDSS00181Y
D27
EDSS00181Y
D28
EDSS00181Y
D29
DIODE (SMD) 1SS355
EDSS00355Y
D30
DIODE (SMD) 1SS355
EDSS00355Y
D31
DIODE (SMD) 1N4148
ED1N04148Y
D32
DIODE (SMD) 1N4148
ED1N04148Y
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL(SMD) 100UH TF J
YCTLI1073F
Switches
Ref#
Description
MFR. Part No.
ROTARY SW GPS-0501
EWRT32000S
Crystals
Ref#
Description
MFR. Part No.
X1
CRYSTAL HC-49/U 4.500MHz
EYCAP04500
Connectors
Ref#
Description
MFR. Part No.
J301
PCB CONNECTOR/S 10P PH=2
EX07N48209
J305
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J306
PCB CONNECTOR/S 4P PH=2MM
EX07N48490
J308
PCB CONNECTOR/S 3P PH=2MM
EX07N48350
J309
EX07N48223
Copyright © 2002 CBTricks.com
