Galaxy
DX Radios DX95T2
Extended 10-Meter Frequency Conversion (26.065 - 29.655MHz)
NOTE: If you have even the slightest doubts or the proper equipment , it would be wise to have someone else you trust perform the mod for you. SO TAKE YOUR TIME AND DOUBLE CHECK YOUR WORK!!!! |
1.
Remove
the covers from the radio and locate X3 (grid location E3 Main PCB). Replace
X3 13.560MHz crystal to a 14.460MHz crystal. |
2.
Do a full Alignment of the radio. |
3.
Re-Assemble the unit and check All Bands for Proper operation. |
This will give you the following freqs. in order.
Band A = 26.065 - 26.505
Band B = 26.515 - 26.955
Band C = 26.965 - 27.405
Band D = 27.415 - 27.855
Band E = 27.865 - 28.305
Band F = 28.315 - 28.755
Band G = 28.765 - 29.205
Band H = 29.215 - 29.655
This will cover almost the complete 10 meter range 28.000 - 29.700 and still keep the 11 meter CB.
